Question about Fisher and Paykel Washing Machines
Error 40 Fisher Paykel washer gwl11 - Fisher and Paykel Washing Machines
  • Fisher and P... Expert
  • 554 Answers
40. (00101000) Phase 1 to 5 - Bowl Dis-Engaged Fault
While carrying out a bowl check,
the Display module has found that the bowl is not engaged
even though the pressure sensor indicates that the bowl is empty.
The Motor Controller continues to check for 2 minutes after which time the display this fault.
If restart is on this fault can take up to 4 hours to diagnose.
The first two areas to check are the clutch and the pressure tube.
If these two appear correct,
then the fault could be in the pressure transducer
in the Motor Controller.
Primary Source - Suds
Action - Too many suds, too much detergent has been used.
Restart product when suds have disappeared,
or select a deep rinse option.
Secondary Source - Mechanical
Action
1. Check that there are no clothes or other foreign objects preventing the clutch from reengaging.
2. Next check that the pressure tube has not come off and that it is not kinked.
Posted on Apr 21, 2014
  • 28 Answers
SOURCE: What is a code 52 on the GWL11 Fisher Paykel Clothes Washer?
52 diverter valve fault
Posted on Jun 21, 2008
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
SOURCE: Fisher & Paykel GWL11 Top-Load Washer troubleshooting
I've had my washer for about 8 years. I experienced the same problem - pump stopped draining the machine. I called F&P and "Patrick" told me that I need to 1) unplug the machine, 2) tilt up the front of the machine, 3) spin the pump (plastic blades) until they turn freely (usually counter clockwise) but I turn it both ways till it turns freely, 4) plug the machine back in and press the buttons to get it back where it was - this has worked every time to get the machine going again. I do a lot of "dog laundry" and I'm sure the rugs/dog hair cause the problem. Hope this helps!
Posted on Nov 16, 2008
  • 12 Answers
SOURCE: washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
Posted on May 14, 2009
SOURCE: Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Posted on Jun 02, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
How do I repair Fault Code #40 on Fisher & Paykel washer GWL11?
I googled it and found this:
http://www.genuineapplianceparts.net/techsheets/gwl11techsheet.pdf
Jul 20, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl11 fault code 40
your pressure sensor is faulty in the motor controller board.
you need a new motor controller board, Or pressure sensor fitted.
Jan 11, 2013 | Fisher and Paykel GWL11 Top Load Washer
No power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
81 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
