Question about Ovens
F,s i ,e,k,r,h ka romantic mining - Ovens
Romantic
MANY WOMEN WOULD LOVE TO FIND A GUY THAT LOVES TO COOK DO YOU LOVE THE LAUNDRY ROOM?
Apr 21, 2014 | Ovens
Sira po ung bulb.
May nabibilin bulb na pamalit dyan kung dito ka lang sa maynila may piyesa sa Raon
Aug 13, 2011 | Ovens
MAKE A ROMANTIC WORD WITH REARRANGE THE U L D N V H S E
u l d n v h s e a romantic word pls solve
Mar 29, 2011 | Ovens
SELF-CLEAN
Here is a link to your manual.
Owners Manual
FYI - The '55' in your model number should be 'ss' for stainless steel.
May 21, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Is there a recall for this oven? Won't heat after cleaning
no recall, it sounds like you blew out the high limit thermostat, this is common on ka ovens the temp of the self clean cycle near 900 degress blows their thermostats, its a safety device it blows when unit gets to hot, usually range between 30-80 dollars, you could call for service or u could repair. if so remove to trim pieces usually two screws on trim from inside, then remove screws that hold unit in cabinet, i suggest getting two people then remove oven out or set on sometin to support it, oh yea turn off power to unit at breaker before servicing, then remove back panel to unit usually screws all the way around on back panel. then locate the thermosat on back, u can test it with a meter for continuity if it reads anything its good if nothing then replace the part....
hope this helps let me know how i did thanks
Feb 19, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Feb 12, 2010 | KitchenAid Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
My kenmore electric oven says locked with and F5 code on it.
I unplugged mine for a few moments and voila! Dinner was finally mine! m
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Clouding of upper oven door
yes the seals have gone ka-pute
this equipment looks good but falls apart faster than our older models when we all were growing up
http://www.reviewcentre.com/reviews105062.html
Nov 21, 2007 | Neff U1661 Double circotherm super...
OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
Nov 01, 2007 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
10 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
