I have a sharp carousel model R8310E, everytime i turn it on it blows the fuse and it makes a funny noise,can you help and tell me what should i replace or do to fix it?
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Sharp Carousel R-1461A
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If
of the oven.
When
If
it goes dead or blows the breaker (or GFI) when you plug it in or open or close
mount.
then test it again.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your
SOURCE: Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
SOURCE: Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
SOURCE: User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
