Question about Generac Electrical Supplies
Loss of Speed Control
Generac 13 kW air cooled, LP vapor. After startup, speed and voltage regulation is good (119 - 121v) under moderate load for about 5 minutes. Then speed and voltage begin to fluctuate wildly (102 - 122v). Stepper motor throttle linkage moves sharply. Not sure if stepper motor is trying to respond to fluctuations or is CAUSING the fluctuations. Bad control signal coming from Control Circuit Board?? Already replaced the Voltage Regulator Module but no joy.
2 Suggested Answers
  • 16 Answers
SOURCE: generac portable generator over voltage even with new control board and regulator
is engine running at 3600 to 3700 rpm at full load. most small engines run at this speed.you can buy a small tach on ebay TINY TACH.. you have to know what the engine speed is
Posted on Mar 05, 2013
Generac power management module install
Mount the transformer on the generator. Hard wire it into a 120 vac plug. Run wires to the module and connect to the coil on the relay. Now run the load you want to disconnect while the generator is running to the load terminals of the relay in the module.
Sep 10, 2016 | Generac GUARDIAN Air-Cooled Automatic...
Why doesn't it start?
gen sets have to be run at set rpms so that the voltage and cycles are correct for the applications
with the rpms as little as 100 rpms below requirement , the voltage will be down , causing a brown out which burns out electric motors and if the rpms are low the required cycles will also be off which affects electronic equipment
service the gen set and find out why the rpms are not at the set level
Jan 09, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
Nov 28, 2013 | Generac Power Systems Generac 5522 14 Kw...
Generac portable generator over voltage even with new control board and regulator
Mar 04, 2013 | Electrical Supplies
Under voltage alarm /shutdown on generac 10 kw gen.
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Sep 18, 2012 | Generac 6051 Guardian Series Air-Cooled...
I purchased a new Generac 20 KW air cooled standby generator. It shuts down under its excercise program and lists a low voltage fault code. I can start the unit in the manual mode and it starts and runs...
under warranty , you best have to wait the time as anything you do to fix it will void the warranty which will suit the service agent just fine
if you void the warranty he will get 2 hours travelling time plus the cost to repair time so don't touch it
Jan 05, 2018 | Generac Power Systems Generac 5522 14 Kw...
I have a generac 22kw model QT02224anan that will run for a few minutes then shut down , then the over speed led is lit. It only happens when it is under load or during a power outage. it goes through...
its possible the overspeed is set to sensitive. or your rpm are to high. these are preset in the factory as a safety, check your manual to ensure your rpm speed is in the pre set area. generators will do this under load when you have a big load on them or take a load off. the governor will some times over compensate causing it to trip on overspeed.
Aug 10, 2011 | Generac Power Systems Generac QT02224 22...
Electrical Supplies Logo
24 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
