Icd9 karapandzic flap - Computers & Internet
Think flap might be stuck because I cant get any heat need to know where the flap is located.
The flap is called a blend door. Google and you will find videos on YouTube.
Jan 25, 2016 | 2003 Buick Regal LS
Duct work goes to crawl space. Apparently there is a flap in the duct work that constantly flaps back and forth like a loud ticking clock. How to stop it?
need to go ino crawl space and their should be a handle with a wing nut on the side of duct --the flap is an air flow reducer dont tighten with flap in closed position since it will shut air off from flap past
Aug 27, 2015 | Cars & Trucks
The ice flap on my freezer will not stay open. If I reach up and grab the flap as it's opening, the ice will flow freely. But if I don't grab the flap and keep it open, the ice won't dispense. It's no
Kristen,
Thank you for giving more information. I believe you will need to replace the flapper on the ice dispenser. I based this answer on the following: you mentioned when the door is held open ice comes out. Let me know if this helps. As you may know, there are several different things that could cause this issue, but this is the most common one of them. Here is a how to video on this type of repair:
Jul 21, 2014 | Frigidaire Refrigerators
Ice dispenser
The solenoid that opens the flap is not working. You'll need a repairman to get to it .
Jul 21, 2014 | Frigidaire Freezers
The chain from the handle to the rubber flap appears to have come loose I cannot determine where the chain connects to the rubber flap. At the end of the chain there is a round link that now just hangs.
That ring at the end of the chain is supposed to connect to the rubber flap directly at one side of the flap is where it connects to the stand pipe, sort of a hinge. directly opposite of that should be a small hole molded into the flap. if there isn't any it probably wore off. You can replace just the flap if this is the case. About 5 bucks or so.
Sep 04, 2010 | Toto Aquia II Dual Flush Toilet
2000 lincoln ls ac is blowing hot air on pass side
On the central console is the A/C module. Inside A/C module are driver's side & passenger's side air flaps for mixing hot & cold air and directed air flows towards driver's side & passenger's side according to driver commands. The passenger's side flap for mixing hot & cold air according to driver commands is bad. Flaps are actuated by electrical step by step motors. Could be damaged the flap actuator (motor), the flap mechanism (blocked in "HOT" air position), and / or electrical supply wires. You must access the passenger's side flap for mixing hot & cold air, and see what happens when you command cold air to the driver's side: flap mechanism, flap actuator, supply wires, ... Repair & replace bad pieces and test the A/C system.
Aug 12, 2010 | 2000 Lincoln LS
Flap for ice dispenser does not work
Most likely the flap has frozen pull the Ice maker out and operate the ice dispenser push the dispenser flap and see if it it is free, if not pour warm water on it to free the flap.
Jun 21, 2009 | GE Refrigerators
Fridge compartment too cold.
Most bottom mount freezer units work by diverting some of the cold freezer air up to the refrigerator through a duct that vents to the top of the refrigerator A thermostat in the refrigerator closes a flap in the duct when the refrigerator is cold enough.
It seems like the thermostat or flap is not working in your refrigerator. You can troubleshoot this by turning the refrigerator to the full warm setting and turning the freezer knob in the cold direction until you hear the refrigerator turn on. Place your hand near the vent at the top of the refrigerator, if cold air comes out that means the flap is not closing like it should.
If the flap is not closing, it might be frosted open. Pop the plastic vent off (they are usually held in with snaps) and inspect the flap. It should open when the fridge knob is turned in the cold direction and close when it is turned in the warm direction. If there is no frost jamming the flap, and the flap is not moving, the thermostat is likely defective. See the pictures below, one is flap open and the other is flap closed.c0498df.jpg67c95ca.jpg
Dec 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
The flap on my water and ice dispenser is forming ice inside and outside of the ice container. The flap is not closing. How do I fix this problem?
check closely the flap. see if the spring pulling it to close shut is still ok. check the seal of the flap. that seal should not be broke or chipping. it should seal tight to the plastic where it is seating.
if there is even a small opening, frost would accumulate because of the air coming in from the damage flap. this frost would accumulate until the flap itself would no longer seal the opening.
tnx 4 uisng fixya,
drcool
Oct 13, 2008 | Refrigerators
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
