Question about Brother MFC Office Equipment & Supplies
MFC - 5890 CN
I have a brother mfc5890 and i would like to connect this to my laptop. The printer is connected via cable to my pc but this is in another room. I would like to be able to sit in the living room using my laptop and print. Is there any way of connecting the laptop to the printer by bluetooth or another way so i don't have to connect via cable
  • Brother Master
  • 3,904 Answers
If your printer and computer are Bluetooth capable then yes it can be done that way. The other way is through your wireless network/router. If you run a cable from you wireless router to your printer then you can use it wirelessly.
Posted on Feb 12, 2014
Testimonial: "i have an EE router. What kind of cable would i need to run from it to the printer"
  • Jerry Kramer
    Jerry Kramer Mar 01, 2014
    You would need a cat 5e or cat 6 cable to make that connection. It is called and Rj45 connector which is the data cable(looks like a large phone plug)
4 Suggested Answers
lucky1484
  • 90 Answers
SOURCE: cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Posted on Sep 17, 2009
  • 159 Answers
SOURCE: Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Posted on Dec 24, 2009
WHAT WAS THE STEPS TO FIX UNABLE TO CLEAN 50 MESSAGE ON MY BROTHER MFC 5890-CN
Open the scanner lid and close it again. this way you get a "reset" of error code and he continues to wok again.
Jul 07, 2014 | Brother MFC-5890cn Color Flatbed...
Printing via bluetooth
Does the Printer have blue tooth if it does then you should with out any problems but if it doesn't then you need to install it through your network or with a cable .
Feb 12, 2014 | Brother MFC-5840CN All-In-One InkJet...
Hello, I have a Brother MFC-5890CN Printer/Fax/Copier which has a wired connection to my PC (Windows 7) & works very well. However I would also like to be able to access the MFC-5890CN from my Laptop...
download the brother network deployment wizard. Run it and
make and executable. run that exe on your laptop. It should do all
the necessary config for you
May 01, 2011 | Brother MFC-5890cn Color Flatbed...
http://download.brother.com/welcome/doc002358/cv_mfc6490w_eng_net_b.pdf
page 14 shows a diagram of router
This above network user guide document also explains configuring the setup
on the back of the printer look for an ethernet symbol
look at
https://openclipart.org/detail/137839/ethernet-connector-symbol
to see what it looks like
then plug in cat 5e ethernet cable (not a crossover cable )
on the back of the router should be several ports with the same symbol .
Mar 31, 2017 | Brother MFC-5890cn Color Flatbed...
My Brother MFC-5890CN Printer wont print.It does scan.I have tried re-installing the drives but when it gets to the last section the box just asks for the machine to be connected. I have also changed the...
I can't print nothing from my PC or trough network, but still I can Scan, Fax, etc. I'm using Windows 7 Home Basic, I already installed the driver ( "Connection via USB Cable" ) and I have plenty enough ink ... I checked the Settings, Test Page is OK, but nothing else want to be pinted. I had a problem with my MFC 5890 in the very begining ( nearly 2 weeks ago ) so I had to unplug and than plug in the USB Cable and in this situation the printing of my "pending documents" was successful, but from few days ago there is no such a thing that could make it print. Please help
Dec 31, 2010 | Brother MFC-5890CN All-In-One InkJet...
Setup von MFC stürzt beim starten gleich
  • Unplug the printer from AC outlet.
  • 2 Make sure the printer is not connected to your PC. Disconnect it, if it is connected.
  • 3 Go to the link to download MFC-7820N driver. Select your operating system and language and download the driver.
  • 4 Double click the downloaded file to extract it.
  • 5 Open the folder extracted in Step 3 and go to the "Setup" folder.
  • 6 Double click the "Setup.exe" file while holding down the Shift key on the keyboard. This will start the installation. Follow the instructions on screen to complete the installation.
  • 7 Connect the printer to your IBM laptop via USB or parallel cable that came with the printer. The MFC-7820N comes with both the USB and parallel interfaces. You can use either one to connect to the laptop.
  • Dec 06, 2010 | Brother MFC-7820N Laser Printer
    It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
    Brother MFC 5890 Print Quality
    Jan 14, 2010 | Brother MFC-5890CN All-In-One InkJet...
    Witch wire connects it to the computer cant find the hole...
    The Brother MFC units with CN at the end of the model number can be connected in two ways.
    1. Via a network using an ethernet cable.
    2. Directly to a PC via a USB cable.
    If you look at the user manual, it will explain how to do so. If you have lost the manual (and the drivers/software that came with it), these are available on the Brother website.
    Dec 31, 2009 | Brother MFC-5840CN All-In-One InkJet...
    Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
    Networking a Printer on a wireless network
    Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
    Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
    60 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
