Question about Korg microSAMPLER
Recordings laptop to korg - Korg microSAMPLER
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
How to recover deleted data
you can obtain undelet software to do this but do not use the machine too much before attempting the procedure, too much use might lead to the areas where data was stored becoming written over. If the data was very important I would contact a data recovery specialist, one with a proven track record.
Good Luck
May 27, 2015 | Korg D3200 Digital Studio
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
I have a korg i4s do not have the manual can you tell me how to record a backing track on it and is there any site I can go to to download the i4s manual
There's so many steps to describe here.
So, this is link to Reference User Manual :
http://www.manualslib.com/manual/686295/Korg-I4s.html
To record a backing track (Backing Sequence Mode), see the manual, start from page 19.
Mar 18, 2010 | Music
Korg mr-1
While this is Mac-related, the information regarding the reset button is helpful and seemingly little-known. This comes from a Korg rep, by the way:
Did you first manually eject the drive from the Mac before disconnecting it by either moving the drive into the trash or using the Eject option from the Finder menu? If you try to exit USB mode without ejecting the drive on the computer first and then disconnecting the cable, this can cause the unit to lock up. Additionally, you’ll notice there is a tiny hole below the volume controls on the side of the unit. You can use a paperclip to push in a button within this hole to manually reset the recorder however this is only recommended in extreme circumstances. Look forward to hearing from you.
-Matt
Sep 02, 2008 | Korg Mr1 Digital Mobile Recorder
Korg microSAMPLER Logo
13 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
