Question about Husqvarna Viking 1
Husqvarna Viking 400 computer problems
When needle thread goes into bobbin, thread loops around repeatedly and then catches, locks up and stops (all inside bobbin area)
  • 3422 Answers
SOURCE: husqvarna sewing machine - viking 400
HI,
Do you mean how to retime it?
Posted on Jun 11, 2008
  • 6 Answers
SOURCE: problem with automatic needle threader On Viking Designer 1 serie
Yes, I fix them all the time. You will need very good eye sight as the wire/metal hook is very small. If you get at an angle where you can see how the hook lines up between the metal flaps that hug the needle, the hook will probably be off center. You will need something very flat, but strong. I have use the exact-o-knife blade, in the handle of course, a knife, and a tiny screw driver. The hook has to line up vertically and horizontally. What usually happens is when we thread the needle it did not line up exactly, and putting pressure on the white tab, bends the hook. Bend it back and you are in business. If the threader does not line up horizontally, the needle threader may have slid down the shaft. This take a special tool. I purchased mine at Sears tools. There are 2 screws on the back of the threader. Move the needle to the highest position and after loosening the 2 screws, you can slide the threader up and down on the silver shaft, this is trickier, because the shaft moves up and down and rotates as it gets close to the needle. I use calipers/hemostats to hold the shaft while I line up the hook.
Hope this helps.
Posted on Jan 07, 2009
  • 371 Answers
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
The bobbin keeps jamming up and is not catching
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 05, 2010 | Husqvarna Freesia 415
Viking husqvarna classica 100, thread tension
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Husqvarna Vicking - The bobbin thread is knotting
Good luck.
Dec 04, 2009 | Husqvarna Viking 1
The bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
Thread ball up
Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 24, 2009 | Husqvarna Designer I
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 23, 2009 | Husqvarna Viking 1
Machine locking up after first stitch
Well I'm assuming this is not a 905 Serger. Here are some tips for bobbin problems on a Viking sewing machine:
Good luck.
Jun 29, 2009 | Husqvarna Huskylock Computerized 905
Bobbin problem
Suspect the needle and hook timing is off causing threads not to catch to make a stitch.
Try these troubleshooting tips:
With machine off, remove the bobbin and bobbin case. Push the needle bar to the left. Lower the needle to the bobbin case and notice when the needle starts traveling upward does the tip of the hook in the bobbin area align with the eye of the needle? If it does not align, the timing is off. If it does, move on to check upper tension:
Good luck.
May 19, 2009 | Husqvarna Freesia 415
Bobbin?
DO NOT RESET THE TIMING!! The timing is off on maybe 1 in 100 modern Husqvarna machines. For the user to change the timing is turning a simple fix into a complicated and expensive fix.
If the top thread is "looping up on the bottom" then you have a problem with the tension on the top thread. Here is what to check:
1. Thread the machine all the way through the eye of the needle. Don't go under the foot.
2. Pull the tread to the side. While pulling, lower the presser foot. You should see the needle bend as the thread gets tight. If not, you have no tension on the top thread.
3. With the bobbin in the case, hold the needle thread and turn the handwheel to bring the thread up. Watch through the cover to see if the thread passes over the bobbin from left to right. When it gets to the right side, the take up lever should pull the slack out and the thread should be pulled up. If it comes part way across but does not pull up, make sure the thread is in the take up lever. If you never see the thread, remove the bobbin case and turn the hand wheel. You should be able to see the hook pass behind the needle while the eye is still below the level of the hook. If the eye is above the hook as it passes the needle from right to left, then and only then consider timing the machine. If the hook passes above the eye but doesn't catch the thread (bobbin case out, needle plate on, presser foot down) you probably have a problem with your needle. Put in a new needle and make sure that the flat side is to the back.
99% of the time when a Husqvarna is not picking up the bobbin thread, something simple has been overlooked. Your symptom of looping on the back of the fabric indicate either a threading or tension issue in most cases, not timing.
Aug 04, 2008 | Husqvarna Viking 1
Loop formation between bobbin and needle
Not enough info provided but will provide procedure for testing tensions:
Good luck.
Jul 14, 2008 | Husqvarna Freesia 425
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
