Question about Brother MFC-5840CN All-In-One InkJet Printer
Printing via bluetooth
Is it possible to connect this printer to a laptop via bluetooth or does it need to be connected by cable . I want to be able to print whilst i am sat in the living room but the printer is connected to my pc in another room
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Does the Printer have blue tooth if it does then you should with out any problems but if it doesn't then you need to install it through your network or with a cable .
Posted on Feb 13, 2014
Mix-it-up
  • 832 Answers
SOURCE: Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Posted on Sep 28, 2007
Mix-it-up
  • 832 Answers
SOURCE: brother printer mfc 240c
no. you should buy a mfc 440cn / 465cn or better -if wireless- a mfc 865cw
Posted on May 15, 2008
lucky1484
  • 90 Answers
SOURCE: cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Posted on Apr 25, 2009
rockitman187
  • 2559 Answers
SOURCE: Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Posted on Jun 04, 2009
xptareq2000
  • 1447 Answers
SOURCE: Just bought a new brother HL-2170W, installed the
it is problem your operating system or driver installation
Posted on Sep 07, 2009
MFC - 5890 CN
If your printer and computer are Bluetooth capable then yes it can be done that way. The other way is through your wireless network/router. If you run a cable from you wireless router to your printer then you can use it wirelessly.
Feb 12, 2014 | Brother MFC Office Equipment & Supplies
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
I can't connect to my HP Deskjet 460 via bluetooth, only via cable (usb). I have installed the printer via cable, and then I try to install the wireless connection via "Add a bluetooth unit" in the "My...
Is your Deskjet still in the default "Private" mode? If so, change it to the "Public" mode.
In the toolbox, go to the printer services tab and choose configure Bluetooth settings. Change the mode to public mode.
Go to --> http:/h10025.www1.hp.com/ewfrf/wc/document?docname=c00625408&cc=us&lc=en&dlc=en&product=466208
Feb 09, 2010 | HP Deskjet 460c InkJet Printer
Wireless printing impossible . How can I solve it?
Hi Paul,
Am sorry to be the bearer of bad news but your printer is not a wireless printer by default. If you would like to be able to print wirelessly and have a bluetooth connection on your laptop/desktop, you have the option of buying an adapter.
The HP bt300 wireless printer adapter uses Bluetooth wireless technology allowing you to print without using a cable. In general, Bluetooth wireless technology is a short range wireless technology that allows connection between devices without requiring a cable. By using your HP bt300, printing is possible from a camera phone, PDA, digital camera, or computer (currently to a computer using the Windows operating system only) to selected HP printers.
Unfortunately, this adapter runs about 145-153$ not including shipping or handling. Am probably giving myself a two star rating by saying this, but your best bet might be to just purchase a wireless printer. I have a wireless 3-in-1 (scan/fax/print) that I bought for about 120$ and it works like a dream. Check out your local Office Depot or Best Buy and take a look.
Hope this helps!
Jan 25, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Can I make this a wireless printer?
You can connect the printer via USB to a single PC or via Ethernet on a network. Though it doesn't have wireless capability built-in, you could also connect it to a wireless router or a print server for a shared wireless connection.
Dec 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
I cant connect my samsung S5233 to my laptop
Hi
Please let me know how are you trying to connect your phone through the cable provided with the phone or through bluetooth?
If you want to connect your Phone with Laptop via Bluetooth, you need to have a Laptop equipped with bluetooth facility built-in, through which you can pair your handset with the handset bluetooth and transfer files.
Else if you are trying to connect it via the cable provided with the phone, you can set your handset connectivity to USB mode and check if your laptop recognizes your phone as a USB device or not, in case it doesn't then you need to install the Samsung PC Studio software which came with the phone and then you would be able to connect your phone to your laptop
Dec 02, 2009 | Samsung Star GT-S5233 Cell Phone
Connecting to printer via Bluetooth but driver is missing
using the bluetooth software on your computer, do not tell the computer you are looking for a bluetooth printer, instead, use search for all devices, then the printer will show-up and select it.
printing via bluetooth does not require a driver (it's just like printing from your cellphone)
Dec 27, 2008 | Zebra QL 420 Thermal Label Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
49 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
