Question about Carburetor Support Bracket Air Cleaner to Tappet Guide 1957-1985 XL
Valve clearance help me i need a valve clearance for nissan bakkie L16 engine
  • 336 Answers
.007 to .011
Posted on Mar 05, 2014
  • Lloyd
    Lloyd Mar 06, 2014
    thanks very much now my ca is fine
What is the valve clearance of nissan caravan
Valve lash is the end of the rocker arm and the valve stem clearance between. When the engine is running, due to the thermal expansion and contraction, if there is no gap between the rocker arm and the valve stem, rocker arm swells, the top valve open, the impact of engine power and economy. Engine valve clearance will be different, usually when the car is cold, the intake valve 0.08-0.10MM, clearance exhaust valves 0.10-0.12MM Car Diagnostic Tool
Aug 26, 2016 | Nissan Cars & Trucks
Nissan extral head valve inlet tight how does
Valve clearance on NISSAN E15 (S) Engine - Nissan Forum
www.nissanforums.com/.../49192-valve-clearance-nissan-e15-s-engine.h...
Mar 3, 2004 - 15 posts - ‎6 authors
Does anybody know what is the valve clearance for inlet and outlet for this type of engine? ... Nissan Xterra Forum · Nissan Armada Forum · Nissan Frontier Forum ·Nissan Titan Forum ..... the head so they don't burn up, especially the exhaust valves.Tight exhaust valves are the #1 reason they burn up.
Nov 28, 2015 | Nissan Cars & Trucks
How do I set tappets on Nissan 1400
With a special tool called a feeler gauge remove the valve covers and one by one bring the cylinders up to top dead center (both valves are fully closed at this point) adjust to factory spec. All adjustments are done cold. If engine is very high miles reduce the clearances in specs by slight amount (.002") to the tight side to account for wear in the valve train parts.
Nov 16, 2015 | 2006 Nissan 1400 Bakkie
Valve clearances Nissan 1400 bakkie
-Yes. What about it...? You mean you want to know what is the clearance specification on the Intake and Exhausted valves....? If so It should on a sticker under the hook, in the owner manual under specification page or in its repair manual.
Good Luck
Mai
Aug 13, 2015 | Nissan Cars & Trucks
I NEED THE VALVE CLEARANCE ADJUSMENT FOR A NISSAN QD 32 DIESEL ENGINE
VALVE CLEARANCE ADJUSTMENT
Application In. (mm)
Intake .010-.013 (.26-.34)
Exhaust .011-.015 (.29-.37)
May 21, 2015 | Nissan Frontier Cars & Trucks
My heater on my Nissan 1400 bakkie stays on warm, moving the arm to "Off" does not help
Hi Johan, I believe the problem will be with either the operating cable or the heater control valve. Sometimes WD40 can work wonders on both, but each should be removed before being sprayed. If the cable or vave is damaged, replacement will be required. Regards John
May 23, 2014 | 2006 Nissan 1400 Bakkie
Nissan valve clearance td25 diesel 4 door 2.4
12 inlet and 15 exhaust is used on most engines unless its a old 60s GT model
Nov 30, 2013 | Nissan Pickup Cars & Trucks
I need to know the vavle clearance of nissan z20 engine.
Mar 20, 2009 | 1995 Nissan Maxima
Carburetor Support Bracket Air Cleaner to Tappet Guide 1957-1985 XL Logo
67 people viewed this question
Top MCA Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a MCA Vehicle Part and Accessory Expert? Answer questions, earn points and help others
