My GE PEB1590 Microwave appeared to have died--nothing on the display. I then pounded on the right side (inside) of the oven a couple of time and the panel lights came on and prompted me to set the clock. I set the clock, but as soon as I try to cook anything, the power shuts off as soon as I press the Start button. I can get the power back by pounding on the inside as before, but if I try to cook anything the power goes out again as soon as I press start.
SOURCE: Microwave Oven Does Not Start Cooking
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at our listing here on
FixYa:.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
SOURCE: Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
I have seen some similar posts about a Panasonic model, but in those posts, the oven starts for a couple of seconds and shuts off. In my case, it never starts--just powers off as soon as I press "Start".
