Question about Electrical Supplies
My porter cable generator stopped producing power. It runs great but produces no electricity ac or dc. All the circuit breakers check ok. any other suggestions? Thanks
ccrozier_agr
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
  • 154 Answers
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
  • 905 Answers
SOURCE: Porter Cable Generator does not produce electricity
Here are a a few possibilities to look at:
1) Bad connection at the outlets themselves (loose wire) regarding neutral, hot wires.
2) Bad Excitation Capacitor. The Exc. Cap. is responsible for energizing the field wiring of the alternator. If the field is not energized, there will not be a magnetic field developed, therefore, no electrical output.
3) Open Field / Stator winding. If Field winding is open, no magnetic field will be developed. If Stator winding is open, no voltage will be induced.
4) Generator speed is too slow. If the RPMs of the engine are too slow, the output of the alternator will fail as well. Note that from normal speed, voltage output will occur but at reducing frequency until ouput ceases altogether, usually at about 47Hz. If your alternator is a 2 pole, engine speed should be 3600 rpm nominal. If alternator is a 4 pole (most aren't), engine speed would need to be about 1800 rpm nominal.
5) Generator speed too fast. If RPMs are too fast, output may fail as well. See above.
6) Excitation Fuse has blown. There is sometimes a fuse in the excitation circuit. To check this, you will likely need to pull the end housing off the alternator. Pay attention to bearings / bushings.
Posted on Nov 27, 2009
stewbison
  • 577 Answers
SOURCE: generator runs fine- does not produce any power-
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Posted on Aug 31, 2011
I have a PowerBack generator. It runs but does not produce electricity. How can I test it?
by plugging in a AC lamp if it lights up it is producing electricity. Suggest looking for circuit breaker on generator as possible cause of problem.
May 25, 2015 | Electrical Supplies
I have a Husky 1850 watt generator with a Subaru motor. The motor runs great but will not produce AC. It was working fine then suddenly the lights went out in my garage. I replaced the diode but did not...
A couple of things would be worth checking into. Of course, I'd pretend that you checked the output fuse or circuit breaker? If you can check for voltage directly from the stator or armature and check the results. Nothing? If it has them, could be brushes. Also, if it's a fuse, don't just do a visual...check it with a test light or multi-tester of some sort.
Jun 12, 2014 | Electrical Supplies
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
I have a coleman vangard generator 7000 watt and it will not produce power any more,when it quit producing power it was running and then just up and stopped producing power but the motor was still running....
gen sets require a dc voltage to energize the field windings and there is a voltage regulator built in
That could be faulty
talk with your local genset repair shop to get ideas
May 27, 2017 | Coleman Electrical Supplies
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
I was running two sawzalls on my pmo43350 coleman generator .Now it stopped producing electricity. the engine runs great but no juice to outlets. ithink i overloaded it.
You may have overloaded it, and it may have been damaged.
Check your circuit breakers first. If there was an overload, they should have tripped if overload was long enough in duration and high enough in capacity.
If the breakers are good, then check your diodes and capacitor regulator in the end of the alternator. While you are here, check your brushes as well.
Do you have a manual for your generator?
Jun 25, 2010 | Coleman Powermate Premium Plus 6250W...
My generator is not producing power runs fine does not make power
Could be several problems on the gen set itself. Check to see if there is a surge protection breaker or fuse, depending on age. Make sure all connecting wires are secure and switches are not set to 240v instead of 120v if you are trying to use outlets.
Jan 04, 2010 | Coleman Powermate Powermate 5000W...
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Generator runs producing no power
Nov 01, 2008 | Porter Cable 5,500 Watt Portable Generator...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
