Question about ASUS A55BM-A/USB3 Micro ATX AMD Motherboard
No sound I have no sound from either the rear or front speaker or mic inputs
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
1.CHECK THE SPEAKERS.
2.CHECK THE SPEAKERS CABELS.
3.THE I/O-SCREENS LIGHTGREEN CONTACT IS AUDIO OUTPUT.
4.GO TO SERVICES AND RESTART WINDOWS AUDIO.
Posted on Feb 12, 2014
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Speakers work but no microphone theres no place to plug in into the new monitor
try to find your mic input at the back or front of the CPU..it has also a output also...
the coor of mic input usually color pink and output sound is green...
Feb 07, 2010 | ASUS LCD Monitor
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
Sound from one speaker with mic plugged in.
Hi I am Vortash it sounds to me that this is linked to the realtek program off shutting off the speakers when the earphones are attatched , it is confusing the Mic plug on one channel as a speaker plug .. check in the advanced section of your mixer settings that you have not got the box ticked that says treat all inputs the same .. and the other that says mute rear when front plugged in ? as does mine .. ( same system that was my problem yours may be diffrent ) if this fails uninstall your realtek drivers and uncheck the realtek devices in device manager unistall them and rebboot the computer installing new drivers .. hope this helps regards Vortash
Jul 21, 2009 | Philips HP-170 Headphones
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Mic not detecting
The Board have three sound port one for rear one for front and one for mic plug in the mic pin into the mic port red colored.
Then go to the realtek control panel located in the taskbar like a red speaker open it and go to the I/O
options and the mic options turn on front mic.
Jan 31, 2009 | Intel D101GGC Motherboard
Bad front audio jack
In most cases the front jacks are in addition to the rear ones. It's not an either/or situation. If the speakers are connected to the rear jacks (usually green for speakers and pink for mic) and there is no sound, you might have a problem with the onboard sound. Try connecting to the rear jacks with a good set of speakers and try it out. If this doesn't work then we can go from there.
Dec 29, 2008 | E-Machines W3107 (RBW3107) PC Desktop
Front panel how too
Hi slider1958,
You want to connect the new case's front sound & mic.
Just about every case will come with a pre-assembled connector for front USB's & sound & mic. Your board has a set of ten pins used just for this. They are loacted just under the boards rear external sound / mic silver housing. Noted in your manual on pg. 15. Named AUDIO1.
def37da.jpg Notice there is one pin missing. Line your case connector to match.
The manual is uncleare if you are able to use both rear speaker & front speaker at the same time. I would think not. Newer boards with HD do allow this.
Good Luck & Kind Regards.
& please vote.
Mar 18, 2008 | Intel Motherboard
MSI 915o comboAudio front panel
Some cases come with a Mic & speaker jack/ cable. These jacks sit within the case. Rather than using the rear Mic which is (colored pink) & speaker (colored green). These 2 colored cables run from the front of the case & out through an emty hole in the back of the case. Which you connect them to the rear of the boards Mic in (pink) & sound (green). Now you can use your front audio jacks for both mic & sound. This may sound strange but I have come across many cases just like this. Its not uncommon to have 2 front usbs & a 1394 connect on to the board as well. Without your manual I'm sorry I can not help you fauther.
Jan 02, 2008 | MSI 915P Combo-FR Motherboard
ASUS A55BM-A/USB3 Micro ATX AMD Motherboard Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
