Question about Miller Trailblazer 301g Cc/cv, Ac/dc Welder. 10,000 Watt Generator 17.4 Hrs
How much is a used miller trailblazer 301g cc/cv,ac/dc 10,000 watt Generator
2 Suggested Answers
luis_david
  • 407 Answers
SOURCE: I have a miller trailblazer
Hi:
Probably your machines just overloaded; the engine will run and produce voltage but no weld output.
Check your fuses F1 and F2, if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Posted on Apr 28, 2011
Why does the welder quit arching after 30 minutes?
Motors and generators are the same in this sense. The winding of a field coil is defective. The winding heats up with use and the winding expands causing it to short out and quits doing it's intended purpose. An hour of cooling allows the winding to contract thus clearing the short circuit. A good motor rewinder person can find the defective winding with an oven or heat gun and can rewind it for a fraction of a new welder generator.
Oct 07, 2014 | Miller Trailblazer 301g Cc/cv, Ac/dc...
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
Gas runs out of carb drain on miller welder generator 301g trailblazer
if it is the float bowl drain leaking, close the drain. If it is the vent, clean float bowl and needle and check level. Next time, drain the fuel out of float bowl after you run it if not planning to run it for 30+ days. That is why they put drains on generator carbs. Modern ethanol turns to gum real quick. Tell you congressman you think ethanol sucks and the new 15% ethanol the farm lobby is trying foist off on us is going to be a disaster for small engine owners.
Apr 10, 2013 | Miller Trailblazer 301g Cc/cv, Ac/dc...
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
I have a miller trailblazer 301g. It worked fine yesterday and now only the 120/240 volt outlets will work. No weld output and also the idle will not kick down. when I opened the unit the only visable...
Hi:
Good Luck.
Apr 28, 2011 | Miller Trailblazer 302 Welder Generator...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Arc start board
At your nearest Miller distributor (almost all gaz reseller)
Jun 03, 2009 | Hobart Welders Champion 500433A Factory...
Miller Trailblazer 301g Cc/cv, Ac/dc Welder. 10,000 Watt Generator 17.4 Hrs Logo
29 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
