Have bought a Julian Bowen TV Bed, but there is no remote control for the lifting of the mechanism. Is there a replacement out there?
2 Suggested Answers
  • 26 Answers
SOURCE: I have a Logitex Z4
online goto manfacture with model number
Posted on Sep 21, 2011
I have the adjustable bed, but have lost the remote control. Two #'s that I see are 17500249 & 062805.
ADJUSTABLE BED ACCESSORIES AND SERVICE
adjustablebedmart.com/accessoriesservices.html
REPLACEMENT HAND CONTROLS We have both hard wired and wireless remotehand controls. Does your hand control look like one of the two on the left?
Sleep Number Bed Replacement Parts ' Sleep Number
www.sleepnumber.com/sn/en/.../bed-replacement-parts
Select ComfortREPLACEMENT PARTS. Remote control. Most issues with your remote can be easily resolved by following certain troubleshooting steps. If your remote is ...
Jan 25, 2016 | Televison & Video
Innovage Jumbo Universal Remote Control
try google for code, because there should be directions
Dec 27, 2007 | Televison & Video
Orthomatic adjustable bed
You have to contact the manufacturer. Due to the age of your bed, the manufacturer may or may not have a replacement remote control.
Sep 22, 2015 | Televison & Video
Replacement remote control not working on TV
What is the brand name of remote control you bought?
Jan 21, 2013 | Televison & Video
I am having an 6 and 20 error !What should I do to fix it?
11_24_2011_4_20_49_pm.jpgRemove flat bed(remove screw under control panel sticker, remove control panel, remove flat bed screws) take out scan head unit, observe any breakage in mechanism as shown in the snap shot,if found breakage replace scan head mechanism,if not replace scan head...clean flat bed glass neatly, fix all back.
Nov 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Dear expert, Our dog chewed up our "remote control unit model: AR-DB4". We live in Curacao, so my question is, where can we order another remote control for our Fujitsu air conditioning? ... It's...
Get your Dog to the nearest VET immediately. The next thing is to ask your Fijitsu dealer for a spare remote control.
If not then you must check out if the multipurpose remtoe will work out with this model.
Get help from an accessories shop to give a remote to test/replace before buying.
Sep 11, 2010 | Fujitsu 22U Air Conditioner
How to replace 2001 s10 pickup fuel pump
This is not a full answer, but a tip on an easier way.to get to the pump. Instead of removing the gas tank. Just pull the bed off the truck! I guarantee that it will be easier. I did this on a 2001 S10 and it took less that an hour to remove the bed.
Remove the spare tire, and the tube that the tool to lower the tire goes through. You will need to unplug your tail lights under the back or the bed on both sides. There is also a grounding screw for the tail lights on each side that needs to be removed. Remove the screws that hold the gas tank filler hose to the side of the bed - right by the filler cap. Remove the tailgate (to make the bed lighter). Follow the frame down the length of the bed and you will find the bolts holding the bed on. There should be 6 or 8 bolts. My S10 had 8 bolts and my son's full size Chevy PU had 6 bolts (go figure?). Then just lift the bed off the truck. We did my S10 with 3 people and it had a camper shell and rack on it. My son's full size truck was lifted off with only 2 people. I would suggest 4 people however - one on each corner to make it easier to lift and control.
Replace the pump as described above and then you can start the engine to make sure everything works before setting the bed back on. NOTE: The fuel pump grounds back with the tail light ground. If the engine doesn't start right away, try grounding the wire back by the tail lights. It works like a charm. This is an especially nice way to do it if the gas tank is full! I spent 18 years as a professional mechanic and this is one of the slickest, least known tricks I have come across. I wish I'd known about it when I was wrenching for a living! Cheers!
Apr 20, 2010 | 2001 Chevrolet S-10
Restricted channels cannot figure out how to reset to factory settings
Pressing the menu button should bring up options to adjust the color ,tint,etc. look for antennae options or parental control options to lift the restricted channels. hope this helps.
Bobalix
Apr 18, 2009 | Televison & Video
My remote fell off my bed and fell apart and now doesnt work. its an rca tv 244889 remote control. can someone please help fix it. Thanx
You should be able to fix the remote yourself with a screwdriver. if the plastic has broken of the circuit board has broken all you can do is replace it im afraid.
Mar 10, 2009 | RCA 244889 Remote Control
I have a ruined Toshiba Remote Control thanks to my Cat!
Hi redead,
I am sorry to hear about the accident!
Our PartSearch department may be able to locate a replacement remote for you. You may either visit http://bestbuy.partsearch.com or call 1-888-Best Buy™ to see if we have a remote that will meet your needs.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 15, 2008 | Toshiba CZ27T31 27" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
