Question about Canon SELPHY CP780 Thermal Photo Printer
Canon selphy CP780 paper cassette error
Paper is inserted correctly but keeps saying theres a paper cassette error.
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
SOURCE: "paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Posted on Aug 02, 2009
MIlfordPrint
  • 90 Answers
SOURCE: Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Posted on Aug 03, 2009
SOURCE: cassette has paper in it; fresh ink cartridge; can
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 21, 2009
Testimonial: "That was exactly the information I needed. It still needs a little push on the paper once in a while, but I'm back to printing. THX"
Paper size incorrect selphy cp780
i have selphy cp910 coming option paper size incorrect why.pls can you any solation
Nov 05, 2013 | Canon SELPHY CP780 Thermal Photo Printer
Keeps saying paper cassette no set correctly or objects blocking path
I was also stuck with this error message for a while. It turned out to be a 4x6 photo paper got stuck in back in a place that was not easily visible. I had to detach the double-sided paper module from the back, tilt the printer on its side and reach in with fingers and pliers to pull it out. The error message was correct, that something was blocking the cassette tray even though you could push the tray all the way in!
Jan 31, 2012 | Epson Artisan 800 All-In-One InkJet...
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
I have the paper in and replaced ink carr. and it is saying no paper or cassette incorrectly inserted
try to see if there is a paper jam.
If not try putting the paper back in and pushing it up against the back so it fits snug.
Also try taking the ink out and putting it back in.
Feb 22, 2011 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Printer says "error on paper tray". The paper is
Are you getting a specific error message or error code?
Jan 03, 2011 | Canon SELPHY CP740 InkJet Photo Printer
I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Dec 17, 2010 | Canon Office Equipment & Supplies
"paper-feed error"
Jun 24, 2009 | Canon Selphy CP510 Thermal Photo Printer
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
Canon SELPHY CP780 Thermal Photo Printer Logo
111 people viewed this question
old marine
old marine
