Question about Electrical Supplies
No output voltage - Electrical Supplies
  • 37 Answers
Probably a bad capacitor. Go to a place that sells electronic stuff, electric motors or industrial lighting with your old one and they can probably get you a new one for 10-15 bucks.
Posted on Feb 16, 2014
1994 Jetta head lights fuse's are right but no lights
Check for voltage at the headlight connectors with the light switch turned on. If there is voltage but your lights do not illuminate, your bulbs are burned out. If there is no voltage, verify that there is supply voltage at the output of the light switch when lights are turned on. No output voltage, first check continuity between the switch and the lights, then check for voltage at the switch input. If there is input voltage but no output voltage, replace the switch. If there is no input voltage, check the wiring between the fuse panel and the switch.
May 07, 2015 | Cars & Trucks
Output voltage adjustment
Output voltage is based on 3600 rpm @ 60Hz. Sounds like your generator is over speeding slightly. Put a Frequency meter on the output of the generator and tune it to 61.5 Hz, that will get your generator in the 3600 RPM range.
Jul 17, 2014 | Dewalt DG7000 Heavy-Duty 7000 Watt Gas...
Output transistors
a transistor has 3 leads,[emitter current, collector current, base current, i am going to give you list of options that the transistors can be used for and it depends on the configuration of the circuits.
input resistance, current gain, voltage gain, output resistance, power gain, voltage gain, (input and output power) + [input and output voltage] and {input and output resistance} + input and output power gain.
18 various formulas to a range in groups of 2's
Apr 14, 2014 | Volfenhag ZX-7170 Car Audio Amplifier
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
I have sony J21mn11. problem not power on only red lit led only.i check all the components on the power supply area and horiz. output D1878 all are good. there is power IC STR S6707 on power supply area. i...
If you have a digital tester or analog try to check the voltage reading from the power supply if high or low or no supply.Check first following voltage location and section. * Check the AC voltage from ac cord to fuse and before the bridge type diode. * Check the DC voltage after the bridge type diode.if normal voltage. * Then check the voltage into the filter capacitor to regulator ic.the power ic.If theres a input voltage in the power ic,check the output voltage going to harizontal output.If no output the problem is you power output.You need to replace it.
Jul 12, 2011 | Sony Televison & Video
Battery is not charging when connected to charger
The problem might be in the battery or in the charger. If you have a multi-tester check the output voltage of the charger. The voltage output must go with the rated voltage in the battery. If there is output volyage in the charger then the problem is your battery. If there is no output voltage then the problem is your charger. Take time to check both the charger and the battery to make sure which to replace.
Dec 07, 2010 | LG Shine KE970 Cellular Phone
My vizio gv42l fhdtv 10a picture flickers like a strobe light, on every input. had the tv since 08. inverter board? main board? Thanks Robert
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Jun 03, 2010 | Vizio GV42L 42 in. LCD Television
No power whatever
Check voltage output of the power supply.
  1. If below the indicated voltage on the output terminals, replace the capacitors across the output terminals with the same specifications.
  2. If there's no voltage output at all and the fuse is intact, replace the 8-pin power regulator IC with same specifications.. It is usually DH321 IC.
Sep 26, 2009 | Philips CDR770 CD Recorder
04 zx6r code 15
some info from the manual (636) fault code 15. hope it helps??
Atmo- Absolute Atmospheric If the atmospheric pressure sensor system fails
15
spheric Pressure (the signal is out of the usable range, wiring short
Pressure Pa =100 mmHg - 900 or open), the ECU sets Pa at 760 mmHg (the
Sensor mmHg standard atmospheric pressure).
Atmospheric Pressure Sensor (Service Code 15)
Input Voltage Inspection
NOTE
o Be sure the battery is fully charged.
o The inspection is the same as "Input Voltage Inspection"
of the throttle sensor and the inlet air pressure sensor.
• Turn the ignition switch OFF.
• Remove the ECU (see this chapter). Do not disconnect
the ECU connectors.
• Connect a digital voltmeter [A] to the connector (8), with
the needle adapter set.
Special Tool· Needle Adapter Set: 57001-1457
Atmospheric Pressure Sensor Input Voltage
Connections to ECU
Meter (+) --+ BL lead (terminal 1)
Meter (-) --+ BRISK lead (terminal 14)
• Measure the input voltage with the engine stopped, and
with the connectors joined.
• Turn the ignition switch ON.
Input Voltage at ECU
Standard: 4.75 - 5.25 V DC
*If the reading of input voltage is less than the standard
range, check the ECU for its ground, and power supply
(see this chapter). If the ground and power supply are
good, replace the ECU.
*If the reading is within the standard range, remove the
seat cover, and check the input voltage again at the sensor
connector. *Remove the air cleaner housing (see Air Cleaner Housing
Removal).
• Disconnect the atmospheric pressure sensor connector
and connect the harness adapter [AJ between the main
harness connector and pressure sensor connector.
• Connect a digital meter to the harness adapter leads.
[8] Atmospheric Pressure Sensor
Special Tool - Throttle Sensor Harness Adapter #2:
57001-1408
Connections to Sensor
Meter (+) -l' BL lead [C]
Meter (-) -+ BRISK lead [OJ
with the connector joined.
Input Voltage at Sensor Connector
*If the reading is out of the standard range, check the
wiring (see wiring diagram in this section).
*11 the reading is good, the input voltage is normal. Check
the output voltage.
Output Voltage Inspection =
• Measure the output voltage at the ECU in the same way °0
as input voltage inspection. Note the following. 8 .~ (j')
Digital Meter (AI ®~O ECU Connector IS]
Atmospheric Pressure Sensor Output Voltage ' 11 .
Meter (+) ~ GfW lead (terminal 4)
Meter (-) -+ BRiSK lead (termina114) tC·lInn, C ,
Output Voltage
Usable Range: 3.80 - 4.20 V DC at the standard
atmospheric pressure (101.32 kPa, 76
cmHg abs.)
NOTE
o The output voltage changes according to the local at·
mosphen'c pressure.
D The atmospheric sensor output voltage is based on
a nearly perfect vacuum in the smaJl chamber of the
sensor. So, the sensor indicates absolute atmospheric
pressure.
*If the output voltage is within the usable range, check the
ECU for its ground, and power supply (see this chapter). If
the ground and power supply are good, replace the ECU.
*If the output voltage is far out of the usable range, remove
the fuel tank, and check the output voltage at the sensor
connector [A] (when the wiring is open, the output voltage
is about 1.8 V).
• Connect a digital meter [A] to the harness adapter leads.
[8) Atmospheric Pressure Sensor
Special Tool· Throttle Sensor Harness Adapter #2:
57001-1408
Meter (+) -+ GfW lead [C]
Meter (-) -+ BRlBK lead [OJ
Output Voltage at Sensor
cmHg abs)
*If the output voltage is normal, check the wiring for continuity
(see next diagram). *If the output voltage is out of the usable range, replace
the sensor.
Apr 17, 2009 | 2001 kawasaki ZX-6R Ninja
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
