Question about Ricoh Aficio™ SP-C210SF Printer
OUT OF CYAN AND WANT TO PRINT ONLY BLACK AND WHIE
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Go into properties and select black and white for starters
Posted on Apr 12, 2014
Please I have an oki printer C831 that's printing only yellow and black on any printing am using it to print please help
I would think you have broken ribbons cables to the cyan and magenta LED print heads. As all the heads are the same I suggest you swop the black and cyan print heads around and see if cyan prints and black does not. That will prove is the print heads are ok. If they are then the ribbon cables need replacing or they are dirty at the heads. It could be just a case of unplugging them, clean them, then plug them back in again.
Oct 21, 2017 | OKI Office Equipment & Supplies
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
Aficio SP C411DN does not print cyan
Well, since you've tried everything, my recommendation is to try to clean the contacts with dry cloth in the left or right side inside the printer where the cartridges place in. see the result
Feb 01, 2014 | Ricoh Aficio SP C411DN Laser Printer
I cannot get my printer to print. I have black ink and all other colours except cyan. I want to print in black and white but it won't work, please help
Hi there!
In order for you to print you need to refill your cyan ink cartridge. Even if you just want to print black and white.
May 08, 2011 | Office Equipment & Supplies
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
I have a HP color laserjet 5500dn that wont print cyan. Has anyone had this problem
Get into MENUS, go to DIAGNOSTICS, PQ TROUBLESHOOTING. Check the cyan.
Clean the contacts on the cyan cartridge, replace the cyan cartridge, Replace the High Voltage Board. The laser scanner for that color may have to be replaced. The DC Controller could be bad.
Also, under DIAGNOSTICS there is a "Disable Cartridge Test".
That test will allow you to remove all the cartridges and swap them around(in other words, put the cyan in the black slot and the yellow in the magenta slot) and print. So why don't you run that test and swap the cyan and the black. Print and see if the problem follows the cyan cartridge. If it does, replace it. If the problem stays with the original slot for the cyan, then the stuff mentioned in the first paragraph comes into play and you may need a tech to look at it and replace parts.
Good luck
Mar 31, 2011 | HP LaserJet 5500 Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
My cyan cartridge shows as empty. My black
No. You need all the cartridges installed with functioning chips for your printer to work. The reason why you need all the colors when all you print is black is because a small amount of color prints when you print black. The manufacturers want to make up their R&D costs on the printers by selling lots of expensive ink.
Nov 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Ricoh Aficio™ SP-C210SF Printer Logo
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
