Question about Samsung SCX-4521F Laser Printer
Paper jam I clean all sensor I cleaned the sensor input and output, but the problem is still there, is not completely out of paper and another paper by the pick up time is stretched, I do not think it's the sensor
  • 26 Answers
Clean the pickup roller, or replace it
Posted on Feb 13, 2014
2 Suggested Answers
  • 220 Answers
SOURCE: constant paper jams
fuser is faulty.exit sensor not working
Posted on Jul 05, 2009
Paper goes part way in then stops. printer continues to run but paper does not go through
Hello,Follow the steps below:
Step one: Remove any loose paperRemove any loose paper from the input tray.
caution.pngCAUTION:Do not remove jammed paper at this stage.Step two: Clear the jam from the back of the printer
  1. Press the Resume button (c01324470.gif ) on the front panel of the product. If the paper jam does not clear, then follow the remaining instructions.
  2. Press the Power button (c01345237.gif ) to turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Remove the rear access door.Press the handle to the right, and then pull out the door.Figure 1: Remove the rear access doorc01427255.gif
  5. Gently pull the paper out of the rollers.
    caution.pngCAUTION:If the paper tears when removing it from the rollers, then check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollersWhile the rear door is removed from the product, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water.Rotate the rollers with your fingers to clean all the way around.Figure 2: Cleaning the paper rollersc00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear door.Gently push the door forward until it snaps into place.Figure 3: Replace the rear access doorc01427257.gif
Step four: Open the top cover and clear the jam
  1. Raise the top cover of the product.Figure 4: Raise the top coverc01423757.gif
  2. Gently pull the paper out of the rollers.
  3. Lower the top cover.Figure 5: Lower the top coverc01423751.gif
  4. Plug the power cord back into the product.
  5. Press the Power button (c01345237.gif ) to turn the product on.
Step five: Reload paper and test the printerAfter removing any jammed paper, make sure the product is functioning correctly by reloading paper and testing the product.
  1. Raise the output tray.Figure 6: Raise the output trayc01423754.gif
  2. Slide the input tray paper-width guide to the left and load a stack of plain white paper in the input tray.Figure 7: Adjust paper guide and load paperc01423755.gif
  3. Slide the paper-width guide to the right until it rests, snugly, against the stack of paper.
  4. Lower the output tray and pull out the tray extension.Figure 8: Pull out the tray extensionc01423756.gif
  5. Print a diagnostic page.
    1. Press and hold the Power button (c01345237.gif ).
    2. While holding the Power button (c01345237.gif ), press and hold the Cancel button (c01235250.gif ), and then release both buttons.
    3. The product prints a diagnostic page.
    • If the page prints successfully, the issue is resolved.
    • If the issue is not resolved and another jam occurs, continue to the next step.
Step six: Service the printerIf you have completed all the preceding steps and are still experiencing a problem, service the product.Thank You.
Dec 26, 2012 | HP Office Equipment & Supplies
Canon MX330 paper output slot has paper jam error. How to clean sensor
I just solve the problem and it's pretty simple. Just turn off the printer and put paper on the printer, then you turn it on and make sure the paper goes out from the other side; and done the warning message disappear (if the paper don't go inside the printer force it to go inside).
Mar 11, 2012 | Canon PIXMA MX330 Office All In One...
Says I have a paper jam but don't
Remove fuser assembly mounted on the top, check paper input & out put sensors clean or blow air on it to clean the dust, if found any sensor flag dis located, locate it properly, if found damaged replace fuser unit..
Feb 01, 2012 | HP Color LaserJet 3500 Printer
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
Paper output Slot Paper Jam
Check and make sure that the exit sensor is clear an free moving.
You can usually move it with your finger up and down.
sometimes they get stuck in the up position.
Oct 02, 2009 | Office Equipment & Supplies
Says have paper jam when there is no paper in the printer
see what you gotta understand
is that right next to the
rollers that pick up the paper
are paper sensors so if those
sensors have been damaged take
a cotton swab dip it in water.
clean the rollers where the
paper is taken in from and
also clean the carriage rod
along which ur cartridges
move(metallic rod).
Remove any loose paper from the input tray. Press the Power button (c01345237.gif ) to turn off the product.Disconnect the power cord from the back of the product.
  1. Gently pull any jammed paper out of the rollers in the back of the product.
  2. Rotate the rollers upward to make sure that they move.
  3. Clear any paper jammed paper from inside the duplexer.
    1. With the wheels facing toward you, unlock the duplexer by pulling back the gray levers on each end of the duplexer.
    2. Open the duplexer lid.
    3. Remove any paper from inside the duplexer.
    4. Close the duplexer lid.
    5. Lock the duplexer by pushing the gray levers up and forward until they snap into place.
Before reattaching the duplexer to the back of the product, follow these steps to clean the paper rollers to remove any debris, dirt, or paper scraps.
  1. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward with your fingers to clean all the way around.
  3. Reattach the duplexer to the back of the product. Gently push the duplexer forward until it snaps into place.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
  6. Load paper in the paper tray.
  7. Try the print job again.
    • If the error message displays again, proceed to the next step.
    • If the pages print successfully, you do not need to continue troubleshooting.
Follow these steps to clear the jam from the automatic document feeder (ADF).Remove all originals from the document feeder tray.
  1. Lift the cover of the ADF.
  2. Lift the ADF mechanism.
  3. Gently pull the paper out of the ADF mechanism.
  4. Lower the ADF mechanism.
  5. Close the ADF cover. Press down until the cover snaps into place.P
  1. ull out the main input tray.
  2. Slide the paper-width and paper-length guides to their outermost positions.Insert a stack of paper into the main input tray with the short edge forward and the print side down. Slide the stack forward until it stops.
  3. Slide the paper-width and paper-length guides inward until they stop at the edges of the paper.
  4. Push the main input tray back into the product.
  5. Pull the output tray extender towards you, as far as it will go
  1. Press the Power button (c01346625.gif ) to turn the product off.
  2. Disconnect the power cord and the USB cable from the product.
  3. Unplug the power cord from the wall outlet.
  4. Reconnect the power cord and the USB cable to the product.
  5. Plug the power cord back into the wall outlet.
  6. Press the Power button (c01346625.gif ) to turn the product on.
Jun 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
PAPER JAM
Look for a "jam door" at the rear of your printer (if so equipped).
You will need : 1 can of "compressed air", 1 container of ether rubbing alcohol or some form of Goo-Gone.
1. In short blasts (NOT LONG ONES) blow through the paper path. Open any paper jam access trays before doing this so the bits escape.
2. Using a SMALL amount of Goo-Gone and either a Q-Tip or small dust free cloth, clean all the rubber rollers on the bars. Cheap paper leaves a fine dust and after time will make the wheels very slick.
Doing this every other month can save you from jams and is just a good maintenance plan for your printer.
Also don't use 'cheap paper'.
Good luck! :)
Dec 02, 2008 | HP LaserJet 1300 Printer
Samsung SCX-4521F Laser Printer Logo
54 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
