Question about Epson Stylus Photo 810 InkJet Printer
Load cassette 1 correctly and press
Screen is read
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Cassette wont go down
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette does not loads it is a fault on the loading mechanism as once the cassette is put into the hodler and pressed down the load motor must take up to forward the mechansim and mode..
2. Defective loading motor, loading drive mechanism or carriage alignment.
3. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
4 Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Jul 23, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
How do I enter code on my 1999 BMW radio cassette? When you first turn it on there is a small 1 in the top of the screen - you enter the first code number and somehow or other I got it to accept that and...
Hi Terry,
Use the radio station/cd preset selector buttons. The one on top furthest left is the first digit. Keep the button pressed or press multiple times until the correct number shows in the read out, then go to the next button and do likewise. Use the same technique through the four buttons and then press the FM button.
Please rate this answer
regards Johngee10
Feb 11, 2011 | 1994 BMW 3 Series
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
Sony dcr-hc38. inserted tape. hear beeps. screen states to "reinsert the cassette". it continues and wont play or record --Solution #1- change the mechnical assembley of casete ...Can you explain how to do...
try it without inserting cassette if it closes correctly and doesnt load with cassette then 99% problem is with drum motor.look out for drum motor connector remove it clean it with pencil eraser and try again if it works, fine or just replace drum motor
Jun 11, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
My office has a CANON IMAGERUNNER 3570 and all of a sudden all of our incoming faxes are printing off landscape instead of portrait style and our faxes are being cut off and we cant read the bottom. Please...
In the cassette change the blue dial back to the correct type, either a4 or A4R (landscape). Sounds like you have to set it back to A4, Blue dial right hand side, front of cassette when you open it.
Or press the paper select button on the copy screen and see what it has been changed to, then change the dial in the cassette.
Jun 09, 2008 | Canon Office Equipment & Supplies
Epson Stylus Photo 810 InkJet Printer Logo
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
