Question about Disney The Chronicles Of Narnia: Prince Caspian sony Playstation 3, 2008
Plaicing stones in right order
Have to lift stones and place them in the right order
Not getting an answer to why I havent received my item
Is this the place? you might try the phone number.
Classic Jewelry.
One Galleria Parkway 1C-7B, Atlanta, Georgia 30339,
phone (770) 690-8629.
Email : info@classicjewelry.biz
Feb 27, 2015 | Clothing Accessories
I need the activation codes for rosetta stone Latin America Version 3. I think I have the 2007 Rosetta stone program set up.
You will find the activation code inside the box on a small card, If you don't find it contact Rosetta Stone with your Order number to get new one.
Thanks,
Questions Rosetta Stone Community
Dec 09, 2014 | Rosetta Stone V3 Spanish (Latin America)...
Chevy SS. can't get the right motor mount to fall back in place
loosen drivers side and attempt to equally lift and lower into place sagging engine mounts make it difficult .
May 01, 2014 | 2003 Chevrolet SSR
God of War 2 walkthrough in english, THE TEMPLE OF EURYDALE,
The Temple of Euryale
Down the stairs, smash the petrified Legionnaires to shatter them, releasing red orbs. Continue on to the right and quickly shatter the petrified enemies before they break free. You can use Golden Fleece to reflect the Legionnaires attacks back at them. Prepare to reflect when their weapon begins to glow blue and they leap up into the air. Start climbing down the ladder at the end of the hall. Down below, some petrified enemies break free and a hulking Minotaur appears.
Quickly shatter the Legionnaires that have yet to break free and then immediately turn your attention to the other enemies. The Minotaur is surprisingly easy to kill if you have a full magic meter. By using Typhon's Bane you should be able to bring the Minotaur down to its takedown stage. When the Circle appears over the Minotaur's head, approach it and press the Circle button to start the takedown. Press the two buttons that appear on screen then finally rotate the Left Analog Stick as shown to finish the beast off.
Unfortunately, once you have killed enough enemies, another Minotaur appears, but at least if you kill off the first quickly, you won't have to face two of them at the same time. For the Legionnaires use Plume of Prometheus (Square, Square, Triangle) and most importantly, use Golden Fleece to reflect their leap attack. If done successfully, you can damage the surrounding Legionnaires with the reflection as well.
After the battle, head through the doorway to the right of the ladder. This hallway leads to a lift. Grab hold of the handle and rotate the Left Analog Stick to lower the lift down to the level below.
PHOENIX FEATHER (12/30): When the lift has reached the bottom, jump up and attack the snakehead on the wall to reveal an unmarked chest that contains a Phoenix Feather.
The two lifts in this room influence the height of each other. Since the soldier removed the handle from the lift on the other end of the room, you must use the lift that still has a handle to raise the lift that does not have one. Raise the lift that you used to reach this room as high up as you possibly can while still allowing you to drop down from the lift to the room below. This raises the broken lift up to that same height, allowing you to then climb up onto the raised lift and scale the wall using the ridges along the wall
Feb 10, 2014 | Sony PlayStation 2 (PS2) Console
Cannot format
From: http://www.anythingbutipod.com/forum/showthread.php?t=31068
  1. Connect the player to the computer.
  2. Double-click the My Computer icon on the Desktop.
    If the My Computer icon is not on the Desktop, click Start and My Computer.
    If the My Computer icon is not in the Start Menu, right-click the Start button and click Explore.
  3. Locate and right-click the disk drive listed as ZEN Stone or ZEN Stone Plus followed by a drive letter.
  4. Select Format.... zen_stone_not_playing_3.jpg File Context Menu Click to enlarge
  5. Ensure the File system is set to FAT or FAT 32. Leave the remaining options set to the defaults. zen_stone_not_playing.jpg
  7. Re-transfer the files back to the computer.
If resetting or formatting doesn't help, you could also try reloading the firmware. Connect the Stone, download the firmware, and then execute the the firmware file.
1. With the Stone disconnected, download and install the Player Recovery Device drivers.
2. Download the Stone's firmware from Creative's site.
3. Boot up the Stone as a Player Recovery Device (also see below).
4. Connect the Stone to the computer and let it load the driver (see here).
5. Execute the downloaded firmware file or Creative's Recovery Tool.
Sometimes, in order to install the firmware, the Stone needs to be connected as a Recovery Device:
1. Make sure the Stone is disconnected and turned off.
2. Press and hold the volume down button.
3. Continue to hold the button until you have performed Steps 4 through 6. If you accidentally release the button, start the procedure again.
4. Press and hold the Power/Pause/Play button
5. Hit the reset button
6. Connect your player to your computer's USB port and after 5 seconds, release both buttons.
7. Once the Stone is recognized, execute the old firmware file.
Hope this helps, and have a nice day! ^_^
Jul 11, 2009 | Creative Technology ZEN Stone MP3 Player
Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Can't get to Bellum!!!!!!!!
Put the stones in this order Square(middle), Circle(left), then triangle(right)
Jun 13, 2009 | Nintendo The Legend of Zelda: Phantom...
How to get the spiritual stone of water
first get a fish in the zora's place go lo the top and speak to the king then go to the lady at the side and do the game then where u dived for the game and u will find a tunnel keep diving till u find a bottle then show it to the king go past the king give the fish to jabba complete the dungeon in side him and u will get the next stone and the game only gets better
Apr 03, 2009 | Nintendo 64 Console
Problem getting sapphire stone
First, go to dotted hole (just south of Sixth island) and use cut to open the steel door.
When you get inside drop into the first hole, then drop into the next 4 in this order: up, left, right, down.
Before you take the sapphire stone, a guy will take it from you.o get it back from him go to the Team Rocket warehouse south of Island five and he will give it to you once you beat him.
Feb 19, 2009 | Nintendo Pokemon Leaf Green for Game Boy...
Cooking
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Feb 07, 2008 | Blodgett DFG-100 Gas Single Oven
Disney The Chronicles Of Narnia: Prince Caspian sony Playstation 3, 2008 Logo
60 people viewed this question
Top Disney Video Game Consoles & Games Experts
James Wishart
NOEL
NOEL
Are you a Disney Video Game Console and Game Expert? Answer questions, earn points and help others
