Question about Motorola Mobility Atrix 2
Short battery life on standby - Motorola Mobility Atrix 2
  • Motorola Mobility
    Motorola Mobility Jun 02, 2014
    Hi Michael Fontana, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Official Brand Answer
  • 3,100 Answers
I'd check out
Posted on Jun 02, 2014
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
Sep 17, 2017 | Sony Ericsson - Xperia PLAY Mobile Phone -...
Short battery life when idle - Sanyo Xacti VPC-HD2000
Strange, mine lasts a very very very long time, but in a standby state (power on, just close the lcd lid). Have you tried to just keep it in the standby state? I will never turn it off unless I need to, like to change sd cards, because it is super quick to capture video and it does not kill the battery.
I have 2 of these dual cameras and John is quite right, the Sanyo HD2000 is not a "normal" camera, its quite abnormally exceptional and way ahead of its time! Having a f1.8 lens, 1/2.5" cmos, 1080p @ 60 FRAMES/second, really makes it not "Normal". You will need a better computer to process the crazy 1080p/60fps images.
Jan 14, 2010 | Sanyo Xacti VPC-HD2000 High Definition...
When in standby how long should the battery on a J700 samsung mobile phone last before need to be recharged? Carphone warehouse says 48 hrs normal
Please find below official product information.
Battery Information Battery Life in Stand-by Mode 250 hours Battery Life in Talk Time 3 hours
Hope it helped.
Nov 26, 2009 | Samsung J700 Cellular Phone
I unlock my nokia n73 but the phone keep switching itself off during useage or after couple of hours on standby. What can I do?
Call you Service Provider and find out if there is a common problem with the particular model and its battery going flat, as this happends with many Nokia N95s. There could be a fault with your battery,
or what u consider small usage could actually just be the expected battery life for the phone, confirm this in the Manual.
also try - http://www.walkernews.net/2007/06/08/converse-nokia-n73-battery-to-standby-longer/
for some tips on making the battery life last.
May 31, 2009 | Nokia N73 Cellular Phone
My Dell Inspiron 1520 seems to use a lot of battery power, even when the lid is closed, and nothing is running. Is there any way to save battery power, without going into standby mode, or turning off the...
How long does your battery usually last? If it lasts 2 hours or more, that's normal for a notebook computer. The standby mode and turning off of hard drives is what notebooks are designed to do to give you more battery life. If you have to have it on and available all the time without going into standy mode, you'll need to get used to charging it every couple of hours. If you want to get more battery life, try the following options:
1) have the display turned off when not in use (this setting can be changed where you set up your screensaver)
2) turn off the wireless function (if available) when not in use
3) have the computer go to standby mode after 10 or 15 minutes of inactivity.
4) lower the brightness of your display
All of the above assumes that you're getting a decent charge and can use the notebook unplugged for 2 hours or more. Naturally, over time, notebook batteries wear down and don't hold a charge as well as they once did. If your notebook is a few years old and you're only getting an hour or so on a full battery, then it is probably time to invest in a new battery. If your notebook is new and you are getting this short battery life, contact Dell for a replacement battery as yours may be defective.
One last thing about notebook batteries. They are designed to be charged up and run down. If you leave your computer plugged in to a/c power all the time while you are using your computer, this greatly speeds up the wearing down of the battery. Whenever possible, you should fully charge your battery and then run the battery down to 10% or less before plugging it back in. This ensures that you get the most battery life on a consistent basis.
Hope this help. Please take a moment to rate the solution. Thanks.
Mar 11, 2009 | Dell Computers & Internet
IPhone 3G Battery Life
All of the iPhones have the ability to connect to an external battery, a charger, or any computer with a USB port. You only need a cable. Does your Treo charge from any USB port? And carrying a cable in your bag is no harder than carrying an extra battery.
I don't think you'll ever see a replaceable battery in an iPod or iPhone. It would make the device too big and it would reduce the battery life--that's right, battery life is worse with a removable battery because the battery has to be smaller. However, you can be sure that Apple will continue to push the chip makers for lower power chips
if this can't help you then add an comment i"ll solve it for you
Oct 13, 2008 | Apple iPhone 3G
Battery life reduced 80%
hi,the problem could be with the battery,change the battery.
hope this is helpfull
Sep 30, 2008 | Nokia 1100
Batteries draining problem?
this problem can be caused by many factors. Use of the phone can drain battery life for example if you use the phone for browsing the web or as an mp3 player, even to make or recieve calls the battery life will not be as long as it would if just on standby. also if the battery hasn't been conditioned or is being over charged this can also lead to short battery life.To resolve the problem try conditioning th battery, basically let the charge drain completely out of the phone until the phone actually switches off, then charge the phone for 24 hours. Next time the battery goes ded only charge for the recommended charging time (this info can be found either in your phone user guide or by contacting the customer service department of your network provider).
Mar 30, 2008 | Samsung SGH-d807 Cellular Phone
Nokia 6680 charge problem
with respect to your low Nokia 6680's low battery, what you need to do is to charge it while switched off for atleast 12 hours.  It is possible for the phone to have 200+ standby time afterwards but that is if its not used at all. You should also disable the bluetooth, as well as the backup ligthing if switched on as all these can dramatically reduce the life of the battery.
Sep 23, 2007 | Nokia 6680 Handheld
Short battery life
Try running the battery down completely (0% so it turns off itself), and charging whilst the phone is completely off (I'd suggest leaving it overnight). Repeat this once or twice, then see if your battery life has improved. Also ensure that you havent left anything on that could be eating your battery up i.e. bluetooth, and contact your supplier if the problem persists, as you should be covered.
Aug 28, 2007 | Samsung SCH-u540 Cellular Phone
Motorola Mobility Atrix 2 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
