Question about Yamaha Music
RHH130 edge cutting out
How can I fix the pv1500 amplifier .it work well but as I switch it off and on again it fail I switch on with dim blinking leds
I would start by checking that the cooling fans are not obstructed, or dirty. It sounds like the amplifier is running right on the edge of thermal cut off (100 degrees for this amp) and when it switches off, rises just above this when the fan stops spinning, not allowing the amp to start again.
I am however just speculating, I've only had a quick look at the schematic.
I'd recommend having the amplifiers serviced by a qualified person, so they can adjust the idle current and check for any bigger problems. Good luck.
Jul 06, 2016 | Music
Drum machine working ok then suddenly cut out, disconnected power supply then an acrid smell of burning came from the machine.
In my case, a -15 volt trace runs under the 1/4 inch connectors and right at the edge of the circuit board. I think slight movement of the connector wears that trace out and in my case it caused it to short to a nearby trace. I ran a 30 guage wire in its place to fix it.
Also see https://www.youtube.com/watch?v=6RJVtQ8i0eY
Apr 15, 2014 | Alesis Sr 16 Stereo Drum Machine
Dean Edge 4 Bass electronics quit working
Clean the contacts on the input jack and battery jack.
Sep 06, 2017 | Dean Edge 4 Bass Guitar
How do you remove the Speakes (HF and LF drivers, Woofer and Tweeter). The cabnit does not open. The woofer is secured from behind, requiring the cabnit to be opened to service any part of the speaker. HOW...
They used what is a called a "Miter Fold Machine" to cut the cabinet from one long piece to something you can fold up that looks like your cabinet.
The short answer is they did not mean them to be serviced. However the two methods you can use to get into it are,
1- locate the corner where the ends came together and try work them apart,
2- get a sber saw (mistakenly called jig saws these days) to cut a window in the back of the cabinet. Save the insert and attach it to larger piece that fits over the hole- you will change the tuning of the speaker slightly, but the larger panel with the cutout attached will bring the volume back close to original and the overlapping edges of the patch cover should be sealed to the cabinet. Paint them flat black like the originals and they will look better when done.
Jun 11, 2012 | ElectroVoice Electro-Voice Zx4 15" Passive...
Eaker seemed to glow around the edges whilst in use is this normal/
Edges of what? The cabinet? The woofer? The center of the woofer? If you have certain lighting, the flexure at the edge of the cone may go through a point that it reflects light.
Sep 14, 2011 | ElectroVoice Ev Zx4 15" 2way Electro-voice...
In some pictures for the Yamaha DTXpress IV Special, the hit-hat has this trigger system under it and other pictures don't.What is it?
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
New bass that has no sound when plugged in to amp.
Rememberthe switch for the battery is ACTUALLY the sleeve of your guitar cable. If the jack fails, the battery will not be connected. Unfortunately, these jacks take a lot of abuse. The jack is really a stereo jack and the connection of the "ring" of the Tip-Ring_Sleeve (TRS) female jack to the "sleeve" connection is what grounds the battery for operation.
Mistakenly using a stereo audio cable will also cause this problem.
Use a good quality instrument cable, preferably gold plated plugs. Bad cables cause a LOT of these problems!
Jun 13, 2010 | Dean Edge 4 Bass Guitar
My keys have popped up on my akai mpk 49
use black electrical tape. put tape on the edge of the key and cut it at the bottom of the mpk
Feb 21, 2010 | Music
DTXPRESS IV SPECIAL changing cymbal(crash) sounds?
hi,
the right crash is a '3 zone pad' (notice the semi-circular groove around the front edge of the pad).
this means you should get a different sound from the bell, the main area of the pad, and the front edge.
In order to mimic a real crash cymbal, the 'crash' sound comes from hitting the edge of the pad.
In reality, there are ribbon switches (like mobile phone keypads) underneath the bell & edge areas of the pad that detect hits to these areas.
Oct 14, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
