Question about Smeg SU45MCX 24" Stainless Steel Built-In Speed Oven With 10
The micro is dead. Micro steel FME20EX2 the clock, and al functions are dead except a faint light inside the micro when i open the door
Micro chef microwave says Lov but the light is on when open door . Clock works. No flashing light jus say Loc
find no instructions for Micro chef try a search thru Google and see if you find it there .
Jul 02, 2016 | Microwave Ovens
Fan and light stay on when door closed. Shut off when door is open. Still heats. Door latch and spring are intact.
These door open or closed mixups are usually caused by the micro switches that are controlled mechanically inside by action of the latch when the door is closed/opened. There are usually 3 or 4 of those switches. Make sure the door protrusions are activating them. They can be replaced by generic ones of the same rating. I would replace them all! They cost less than $2 each. Order them online from a company like Mouser Elec or Digikey. You can test them for operation with the ohms function of a digital voltmeter. Be careful inside of a microwave. Deadly voltages even when off! Get some electrical help if you are unsure.
Nov 16, 2015 | Sharp R530E 2.0 Cu. Ft. Full Size...
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Replaced the 20amp fuse in my microwave. Clock and all lights work but oven will not heat
one or more of the door micro switches are open or shorted..the micro switches tell the unit the door is closed and safe to use.the micro switched are marked normally open or closed..take note when replaceing them..also their is a actuator lever that tells the switch to close or open..it is plastic and connected to the door latch..it can be broken off or bent from heat,,its plastic..make sure its in place and working the micro switch
Aug 15, 2014 | Microwave Ovens
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Smeg SU45MCX 24" Stainless Steel Built-In Speed Oven With 10 Logo
23 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
Your Consultant
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
