How to set it using network cable+
Konicaminolta bizhub210
  • 26 Answers
Enter Utility Mode -> Network setting.
Set IP, Subnetmask, Gateway.
Then use the cd to install the driver.
Posted on Feb 13, 2014
How to install konika minolta with computer
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Feb 18, 2015 | Konica Minolta BizHub C252
Bizhub 224e won't print from computer
Is this machine on a network? if so can other computers print?(IF others can not the machine) If this is a single computer are you using a crossover Ethernet cable. Are you sure the proper drivers are installed go to Konicaminolta to get latest drivers free.
Dec 19, 2013 | Minolta bizhub 200 All-In-One Printer
I can't share my printer ineo+351 i don't have the
You must press Utylity/Counter next open on screen admin setting. (Pass is 12345678) next network setting, IP setting and you can set IP address. If network (card, cable, switch or router) are OK you can print on your Develop. Driver you find on www.develop.de or http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
Nov 03, 2013 | Compatible Develop Ineo 300, Ineo 300,...
I am trying to install my bizhub c250 through network cross cable with my computer. I adopted almost all the instuctions available for the configuration of the same but could not get a print through...
What you have done should have worked.
You may need to enter the IP address into the printer using the printer console not via the computer printer properties.
If it still does not work check the IP address range of your network card, the printer's Ip address needs to be in the same range, ie the first group of numbers must be the same, only the last group of numbers are different.
You may need to use a LAN hub with normal LAN cables and not a crossover cable.
Jul 23, 2010 | Office Equipment & Supplies
How to conect my to the Konica Minolta Bizhub C250?
There could be any number of problems. Drivers, Network settings, ect. If you are the only one that can't print I would try and Ping the machines IP address to see if the computer can see the printer. Also check where the network cable connects to the copier and see if you are getting any communication lights blinking. If not you may have a bad cable. Check the machines job log and see if your print jobs are getting to the machine and are being deleted. If so you may have authentication turned on and dont have the code put in your print driver. You can download the user manuals and drivers from kmbs.konicaminolta.us .
May 24, 2010 | Konica Minolta bizhub C250 All-In-One...
INSTALL SO I CAN PRINT
You have to set up the machines network settings.
Press Utility/Counter
Select Admin
Enter Code 12345678 or 00000000
Select Admin 2
Select Network
This is where you can put in the IP, Subnet, Gateway, and DNS.
Then install the print driver. It is best if you have the driver disk. If not you can download the driver from kmbs.konicaminolta.us
If you have windows 7 download the XP version for your operating system (32bit or 64bit)
May 15, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
I have changed my Internet provider and it has a different IP address than before and my bizhub 250 cannot print now
Press Administrator
Input code 12345678 or 00000000
Select admin 2
Select Network
Here you can change the network settings to match you new Network scheme. You will have to reinstall the print drivers after you correct the network settings. If you have the driver disk it will auto run and find the machine, if you don't have the disk you can download the drivers at kmbs.konicaminolta.com where you can also download the user manuals in PDF format that will go into more detail on changing the network settings.
May 15, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a Bizhub 250 printer that I want to set it up on a network. How can I assign an IP address to this printer?
Press Utility/Counter key
Select Admin
Enter Password 12345678 or 00000000
Select Admin 2
You will find network settings there.
You can also download user manual at kmbs.konicaminolta.us
May 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Network connections
just woke up :) day time here (3pm)
>connect the crossover cable to both printer and computer.
>we already set (but check) the IP address of the equipments. the first 3 set of numbers must be identical and the last set must not. example 192.168.254.1 (computer ) 192.168.254.10 (printer).
>ping the printer
>from http://www.biz.konicaminolta.com/download/
- check the usual (drivers etc)
- run Pagescope Network Setup again.
>i might not be available at a later time (freelancing) but once i'm done i'll contact you asap and we'll do a screen sharing session (prepared one for you).
ohms
Nov 22, 2008 | Konica Minolta bizhub C250 All-In-One...
11 people viewed this question
jasbo
jasbo
