Simpson swf1076 - how long are the cycles supposed to be? A fast wash is taking 2.5 hours?
  • 1294 Answers
SOURCE: Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Posted on Apr 11, 2007
  • 1462 Answers
SOURCE: wash cycles far too long!
you may have the hot and cold hoses connected wrong way round. water flow from hot is often very slow hence the extended times. to check, put on rinse which should let cold water in. see if it is in fact hot water coming in and this confirms hoses wrong way round. just interchange them. smell could be due to using liquid detergent. change to powder type
Posted on Jul 09, 2007
  • 90 Answers
SOURCE: Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Posted on Feb 10, 2008
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
beltronic205
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
Apr 22, 2016 | Simpson Washing Machines
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 22, 2014 | Simpson Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Aug 03, 2009 | Electrolux Washing Machines
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
