Question about Vehicle Parts & Accessories
Convertible top how to clean
  • Andrew Walters Feb 13, 2014
    Hi Michel Laventure, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What material is the top; vinyl or cloth?
    Sergeant:
  • 255 Answers
Go to a specialist cleaner / Valetters and find out what they use.
Some motorcraft places will have some sort of cleaners you can use.
Check Enbay for some ideas of prices.
Posted on Mar 08, 2015
  • Larry Hulvey
    Larry Hulvey Mar 17, 2015
    I use a product called "Top End" made by Surf City Garage. Follow the directions and it works great. I have a BMW Z4 I use it on, looks fantastic.
The cords on each side of my convertable are broken how can i fix this problem can the top still go down
Tonya, Check the attached links, you can also search the internet for top repairers in your area.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Convertible Tops
VW New Beetle Convertible 2003 2010 Convertible top outer shell remove...
https://www.convertibletopguys.com/sitemap/view/107/volkswagen-convertible-top
Convertible Top Side Tension Cables
Mar 05, 2016 | 2005 Volkswagen New Beetle Convertible
I just had a fuel pump and filter put on my 1993 ford exployer and the cadaylitic converters cleaned out but my engine light keeps coming on after it lurches for a moment around 60 miles per hour.
You cannot take apart the catalytic converters to clean them. They are sealed. If this was a shop that charged you for this service then find an honest competent shop to diagnose the Explorer. This almost sounds like an electrical issue (like arcing spark plug wires). If you open the hood in a really dark area, lightly spray some mist water onto the top of the engine while it's running and see small arcing sparks then it's time for new spark plug wires. You can do this little test for free before you take it to a shop.
Nov 24, 2014 | Ford Cars & Trucks
1995 convertible Firebird , Wont Start / Convertable top
Clean the battery cables this may be a corrosion problem, also test the battery and the charging system performance.
Sep 10, 2012 | Cars & Trucks
I have a 93 M/Benz SL500 having problem with the convertible top. The switch for activating the convertible top lights constantly and when driving, a terrible warning noise occor. Everything seem to work...
look around your convertible top and its like you have problem with the black seal some thing there make your convertible top not close good . try look again and i hop you found the problem . look good .let me know .
Nov 16, 2011 | Cars & Trucks
2004 Beetle Convertible, rear window is getting unglued
I had the same problem with the window in my 2003 beetle convertible. I purchased 3m windo-weld super fast A10E2A and single step glass primer A13B5A also 3m. I ordered it online from Auto Body Toolmart. It was very easy to do and is in there really tight. Unlatch the top just enought to release the tension.
1. clean the window and remover any old glue with a razor blade
2. use acetone to make sure the rim around the glass is clean
3. apply thr gass primer and let dry
4. apply the glue which is black so put on a thin bead and I used gloves so I could make sure it was on both the window and also the fabric of the top. You must work fast because it sets up in 15 minutes.
5. Then take blue masking tape and secure the glass by taping all around the top. up and down and from side to side.
6. allow to dry for 6 to 12 hours. the clean off any extra glue with a razor.
The total cost was $39 dollars instead of having to buy a new tp
Oct 07, 2011 | 2003 Volkswagen New Beetle Convertible
2003 bmw z4 top moves sluggishly
Asuming that you re talking about the convertable top. you can try two things. the motors some times do not get lubricated and over time the Grease on the motor gets tacky. By cleaning the motor and reapplying new grease and operating the motor a few times before reinstalling it to work in the new grease. If there is not improvement in the operation of the motor it should be replaced to bring the convertible top back to 'new' condition.
Apr 22, 2011 | BMW Z4 Cars & Trucks
Front passenger top hinge
i used a mig welder too repair mine just get the metal real clean then use a rust converter
Jun 04, 2009 | 1993 Jeep Cherokee Country
Catalytic converter smoking
chech the ignition timing first.usually nissan vehicles has an ignition timing of 10 degrees before top dead center.after that clean or replace the spark plugs.use only unleaded gasoline.
Aug 12, 2008 | 1990 Nissan 300ZX
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
