Question about Compaq Presario CQ60-220US PC Laptop
Homepage opens with 4 little duplicate screens after replacing monitor lcd cable. Everything works but 4 little equally sized screens appear upon boot up. Everything opens with 4 duplicate tiled scree
Any suggestions on why after changing monitor lcd cable I would have 4 screens appear equally sized with grey thick line directly horizontal in middle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 86 Answers
Did you plug one end in backwards?
Posted on Feb 20, 2014
Testimonial: "Took it all apart again. Cables are not reversible."
  • 2 more comments
  • James Krzeminski Feb 20, 2014
    Is it possible to reverse the lcd monitor cable? would it go on wrong?
  • kendrick Feb 20, 2014
    Alot of those micro cables have no little tab and can go in either way, upside down or right side up. Laptops are mostly hell to take apart, but if it was fine before. look at the old cable and see if it can be inserted either way that will give you a clue.You mighta' given a static shock to it. You didn't do your repairs in a carpeted room did you. Never fix a computer in a carpeted room, it makes those little blue static shocks when you walk on rug. They can ruin a computer.
  • James Krzeminski Feb 21, 2014
    My sons computer. The previous cable was shorted out by the left hinge where monitor opens. I'll have to take it all apart this weekend and see if i can reverse the lcd monitor connection. I will also turn computer on while opened up to look at screen before closing up again. What a pain to route cables and put back together! Thanks for your suggestion. I will let you know outcome as soon as I try.
  • kendrick Feb 21, 2014
    And Evan Mayo below said too, those cables don't seat easily sometimes, I'm figuring it's a standard flat flat cable with the, bare flat end, no connector of any sort on the cable the connector is on the board. They go in a little crocked sometime by such a small amount it' almost invisible the the eye. Sometimes they are not all, all, the way in. They can be decieving. They are so small and flimsy. Hope it's just the connect for you, although it is a little project getting a laptop open. If you didn't change any other thing, you should find something to do with that cable install. Godspeed.
Kegtapper
  • 94 Answers
SOURCE: Notebook screen lines
IT may be simple as reseating the ribbon cable on the side of the LCD display- the initial problem indicated that, but now the cable may have become totally unseated. Otherwise it may be just a bad cable. Try plugging the Laptop into a CRT or external monitor, if the picture is fine, reseat or replace the connecting cable to the LCD panel in the laptop. Kegtapper
Posted on Oct 28, 2006
SOURCE: Black Screen
listen the answer is this. screen resolution set to a incorrect setting or video driver installed is not compatible with the hardware in the lappy. what you do is this when you reboot the lappy press the F8 key until it give alist of options boot to safe mode uninstall video driver by going to device manager or reset display resolution in the display setting try the latter first then reboot.
Posted on Apr 08, 2008
SOURCE: monitor problem
I am seeing many people have these type of problem. Why did it happen? I have a couple of vertical line on my LCD. If I applied a little pressure to flex or twist in. It does go away. What does it mean? What is the cause? Is it repairable?
Posted on Apr 16, 2008
ramesh singh
  • 126 Answers
SOURCE: I have a Dell Inspiron 9300
if there is white line in the middle of the screen then first of all turn off the laptop and disconnect the ac adaptor and take out the battery and press and hold down the power button without the power cord and the battery for one minute and then turn on the computer with power cord and the battery and then check it out and still after that if u get it then check it out with the external monitor and if u get a good display in the external monitor then replace the lcd,but make sure that the screen is not broken from inside which u cannot touch and feel it.and if u get a good display in the external monitor then definately replace the lcd screen....good luck
thanks
Posted on Jan 21, 2009
benwabnick
  • 2404 Answers
SOURCE: the screen on my laptop flickers colors and there
Lines on the screen means the LCD is bad and needs to be replaced. The inverter just makes sure the lcd turns on. That wouldn't cause lines on the screen.
Posted on Nov 28, 2009
Replace ribbon cable going lcd compaq presario screen
Please replace it with a brand new flex cable. Please post the "4 tiles miniature screen".
Feb 12, 2014 | Computers & Internet
Connect laptop screen
The option for duplication of the screen is not a hardware related it depends upon the platform/software you are using. Windows from vista(Grid vista) onwards provide a built-in feature to handle multiple screen. I suggest you to update your video drivers and try running the windows file integrity scan this will diagnose if there any configurations files are corrupt.
Sep 20, 2013 | Lenovo ThinkVision L151p (Black) 15 inch...
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Oct 26, 2012 | Computers & Internet
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
Good Evening Sir/Madam,I have a problem on my LCD Monitor,if i open my cpu it appears on the screen of my monitor is"Out Of Range"....what kind of problem is this sir,can you give me...
You have set too high resolution for your monitor. Follow these steps to correct the problem.
1. Switch on the computer.
2. Before you see the Windows logo, press F8 button several times. You will get the boot menu.
3. Select the option 'Enable VGA mode' with arrow keys. Press enter.
4. Computer will boot normally, but with larger icons.
5. Open Control Panel --> Appearance and Themes --> Change the screen resolution.
6. Set the screen resolution to 1024 x 768 (or something close to it).
7. Apply the settings and restart the computer.
This will solve your problem. Wish you Good luck!
Nov 12, 2010 | ViewSonic VA912 19" Flat Panel LCD Monitor
Image stretched widthways
Hi
Depending upon your operating system: Right click on an open area of the background screen. The goto to settings or display settings. From here you're going to want to change the display resolution or display size to match your monitor. Experiment with the different sizes until you get the one that's right for you.
May 13, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Hi, i have a problem with my Dell Inspirion 6400, after replacing Motherboard laptop won't boot up, after pressing power button, all 3 lights comes up (caps, num and scrl lock) and than back off, power...
I would hook up an external monitor to see if the laptop is working. If it is working fine then you must have a connection problem where the LCD plugs into the motherboard. I am willing to bet it is the LCD cable mot seated correctly. If it does not work on an external monitor try switching the memory chips one at a time if you have 2. Everything you mention indicates it is booting but no video. Good Luck Phil
Feb 21, 2010 | Dell Inspiron 6400 Notebook
T-Mobile Dash screen won't light
Consult_roxa
You can open it up and see if the lcd cable has come loose.
The following link provides directions on how to replace you screen. You only need to go to step 7.
After resetting the cable, and it doesn't work, then you probably need a new screen. I provided a link below where you can get those.
Reseat LCD Cable on T-mobile Dash
Replacement LCD Screens for T-mobile Dash
Hope that helps you out.
Nov 12, 2008 | T-Mobile Dash Smartphone
Compaq Presario CQ60-220US PC Laptop Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
