Samsung diamond drum washing machine wa13v5 is overflowing through top loader lid?
My machine is a few years old and never had a problem. Today it overflowed as if not emptying during the cycle, and water poured over through the top loading lid of he machine??
the dr
  • 447 Answers
SOURCE: Washing machine overflows
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
  • 90 Answers
SOURCE: washing machine
check pressure switch hose
Posted on Jan 06, 2008
  • 46 Answers
SOURCE: Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
Krazytech
  • 725 Answers
SOURCE: Hitachi Washing Machine model SAF-2000PX
check the lid switch ... make sure it is make contact and the the actuator is working hope it helps
Posted on Sep 16, 2008
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Posted on Oct 16, 2008
My LG Fuzzy Logic Turbo Drum 13 Kg Top Loader don't stop taking water at any level and then it overflows. What can be the problem or how can I sort this issue out
there is a pressure valve inside.........look around the drum with lid off.......look for thin pipe from bottom of drum to small unit.........that is the valve switch.........remove pipe blow and suck on the valve switch listern for a click.........no click.......replace the valve switch........
cheers
Nov 24, 2016 | LG Washing Machines
How do I remove the drum from my machine to clean it it's a WA13V5 Samsung top loader washing machine
This would be a major undertaking and requires special tools. Your washer has a "Clean Tub" cycle which you should use instead, as instructed, with a special purpose detergent such as (many alternatives are available)
http://www.affresh.com/our_products/affresh_washer_cleaner
You may need to do this twice over if the washer has not so been treated for a while.
If you are saying you have done this and it did not succeed, seek specialist advice from Samsung support.
Jun 16, 2015 | Samsung Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Samsung wa13v5
The seals in the bottom of the drum where it connects to the gear box is going bad. Changing them out is something that you can do but it is not easy. You pull off the top cap on the agitator and then take off the nut and lift the agitator out, then you can see the seals.
Jan 19, 2014 | Washing Machines
My wfe's diamond cross necklace fell between the drum and machine
The top should be held in place with metal clips that insert into the machine. A flat head screw driver will work to pry around the top. You may have to take a few screws out the backside that connects the top to the bottom.
May 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have DE progamme fault...
dE - Door (Front Loader) or Lid (Top Loader) Open Error = Close Door / lid
If error persists, check:
  1. Make sure the load is not too large - try taking some laundry out and see if the error persists.
  2. Wiring harness
  3. Door / lid switch assembly
  4. Unbalance switch
  5. Circuit board for defects.
  6. Check Drum retainer springs are situated correctly and are correctly tensioned.
  7. Make Sure Drum stabiliser struts are not misaligned or broken.
Repair / Replace faulty part.
Nov 06, 2009 | Samsung Washing Machines
Top loader stops and will not drain
sounds like the lid switch. if you have a hole that the lid finger goes in stick a pencil in it and turn it to spin if it spins replace lid switch finger not making contact. if you dont have a hole then try to tighten the screws on the side of the lid.
Jun 23, 2008 | Whirlpool Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
