Question about Xerox Phaser 6121MFP/S Multifunction Laser Printer
Eeprom motor error 3c10 - Xerox Phaser 6121MFP/S Multifunction Laser Printer
Error 3c10
error 3c10 EEPROM data error turn off power and remove power cord from wall wait about 10 minuts and reset power cord and turn on power if clear error code then ok and enjoy.
if not need to reprogram eeprom.
thanks
Jul 26, 2014 | Epson Office Equipment & Supplies
What does the errorcode 3c10 mean on a canon MP640
The ink absorber is supposed to be full. If you can find it, you could try to clean it by pressing paper towels there. Be aware the ink is mean. You can't wash it from your hands let alone from clothing.
Wear rubber gloves and have a bin close by.
After you cleaned the printer, pull out the power cord for a minute or so and then reconnect an switch on.
Jul 17, 2014 | Canon MP640 All-In-One InkJet Printer
What of when 6L is blinking
5 02 Copy lamp lighting abnormalityH2 00 Thermistor open
H3 00 Heat roller high temperature detection
H4 00 Heat roller low temperature detection
L1 00 Scanner feed trouble
L3 00 Scanner return trouble
L4 01 Main motor lock detection
11 Shifter motor trouble
L6 10 Polygon motor lock detection
L8 01 No full wave signal
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication
Jul 15, 2014 | Sharp AR-M205 Copier
Error 3C10 Konica Minolta magicolor 1680MF ?
SOME attempted COUNTERFITTING There is nothing that can be done, Get a tech out who will remove a chip the chip will be sent to Konica Minolta and then to the US SECERT SERVICE for determining what was done. until then machine will remain inop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 07, 2014 | Konica Minolta magicolor 1680MF -...
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
5402 error 2
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get error 1 and no start allowed.
To check and reprogram this EEPROM we have to acess the service routine. This is done by by jumping together pins 1 and 5 of X8 conector, on the base of the electronic board, located behind the power cable panel in the back of the centrifuge. There are about 20 setting or check parameters, but usually 1 or 2 of the described above need to be reprogrammed. Please e-mail me for details: phdeletr@gmail.com.
Error 2 is Motor Tach (Speed sensor) error, caused usually if the cable pops off the electronic board. But the tach sensor itself, who stays in the bottom of the motor drive, could be broken or defective.
Regards,
Paulo H. F. Pimenta
Dec 13, 2013 | Eppendorf 5402 Refrigerated Centrifuge
Error 1 on the 5402 centrifuge how to repair problem
Dear Sir,
In a 5402 Eppendorf Centrifuge, Error 1 states primarily for an EEPROM error. EEPROM is a tiny memory chip that stores individual details of the centrifuge, mainly the microprocessor time base (for correct time set operations), the mains voltage (115 or 230 V, to inform and set the motor current levels), and the imbalance level adjustment for the imbalance sensor. When the centrifuge powers up, these data are readen, and if all OK, the centrifuge is ready to go. If one of them corrupts, especially the 115 or 230 Volt information, we get Error 1 and no start allowed.
phdeletr@gmail.com.
Regards,
Paulo H. F. Pimenta
Dec 11, 2013 | Eppendorf 5402 Refrigerated Centrifuge
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
What is the error U2 ?
U2 04
Content: EEPROM read/write error (Serial communication error)
Detail: EEPROM access process error
Cause: EEPROM abnormality
Check and remedy: Check that the EEPROM is properly set.
Feb 10, 2011 | Sharp AR-M205 Copier
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Xerox Phaser 6121MFP/S Multifunction Laser Printer Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
