Question about Frigidaire Kenmore Washer Tub to Pump Hose 134455900
Changing drive belt on vacuum
I cannot separate base to get to belt
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Turn it over and remove bottom cover and replace.
Posted on Mar 05, 2014
Changing vacuum belt
You have to turn the vacuum over and remove the two small silver screws on the sides of the bottom plate.
Feb 09, 2014 | Eureka 3276AZ Pet Lover Bagless Upright...
The roller does not spin
Hi schrim8...
Your problem is most likely a broken drive belt.
You will have to remove the vacuum base cover, then remove the roller assembly from the vacumm base to replace the belt.
After you remove the roller assembly put the new belt on the pulley inside the vacuum first, then install the belt on the roller assembly and then reinsert the roller assembly back into the vacuum base.
Reinstall the vacuum base cover.
Please take time to rate me
Jul 28, 2011 | Eureka Uno 2998AZ Bagless Upright Vacuum
Hi, My Sebo X1 has a problem... The brush has stopped rotating (just after a noise like a jet engine!). Is this a belt problem? What's the best way for me to check. Thanks, MP
It's possible you have a broken belt, although Sebo belts usually last at least 10 years and often much longer. The first (and easiest) thing to do is remove the brush roll and check that it's not damaged where it mounts on the metal drive spindle. If that's OK, place the machine in a position where you can see the drive spindle then, keeping fingers and clothing well clear, switch on and check if the drive spindle rotates. If a belt is broken, the spindle will (of course) not rotate. The ultimate check is to take the cover off and have a look. To do that, first separate the bag compartment from the base, then turn the base upside down and undo the four deeply-recessed screws. Turn the base over, move the suction tubes out of vertical and just lift the cover off. The belts will be exposed and all will become clear (or possibly not!).
If you need guidance on changing belts, you can search on this site, as it's a question I've answered many times here. If you still have a problem, post a reply here and I'll see what more I can do to help. Good luck!
Jun 02, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing the belt on a sebo upright vacuum cleaner
This machine has two toothed belts and it makes sense to change both while you're at it. Incidentally, this is a job you shouldn't have to do very often - Sebo belts usually last at least 10 years.
So, here's how to get at the belts and change them... NOTE - any use of the words LEFT and RIGHT assume that you are looking from the REAR of the machine.
STEP 1. Separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
STEP 2. Turn the base upside-down and undo the FOUR DEEPLY-RECESSED SCREWS. All the surface-mounted screws are irrelevant to this job.
STEP 3. Turn the complete base right-way up, release the foot pedal and move the vacuum tubes out of vertical. The top cover will then lift off. You will see there are two belts - the pulley device between the motor and the brush roller is the sensor that measures the drag on the brushes and operates the automatic height adjuster to maintain constant drag. To the right of that double pulley is the electronic circuit board - note that it has a sensor that locates within the pulley device, be careful not to damage it.
STEP 4. At the left end of the motor cover, the drive cog is concealed by a small cover. Lift this cover out vertically, noting how it locates in the frame for when you come to put it back. Next, although not essential, it helps to remove the metal lever because if it falls out when you're not looking you may later be uncertain about how to locate the small coil spring. So slide that lever out towards the motor, noting how the spring locates.
STEP 5. Undo the two screws holding the circuit board (take care the washers don't slip away). Then undo the four screws holding the double pulley. Once that's free, you'll be able to change the belts.
Re-assembly is simply the reverse of the above process.
If you need more help, just ask. Please remember to rate this response.
Feb 17, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Roller not turning
If the motor runs when you switch on, but the brush roll doesn't revolve, then there may be a broken belt. I wonder how old your vac is? Sebo belts are very high quality and they usually last 10 years at least.
Before you go to the trouble of checking the belts, check the brush roll and its drive shaft. Remove the brush roll and check for signs of damage at the end where it engages the drive shaft. Also see if you can easily rotate the drive shaft - if you can, there's a belt broken. To confirm, lie the machine down so you can see the drive shaft, then switch on (keep fingers clear!) and look to see if the shaft is rotating. If you can't turn the shaft by hand and it does rotate when you switch on, then the belts are OK but the brush roll may not be locating properly and you probably need a new one.
To check the belts you need to get the cover off the base, as follows: separate the base from the bag compartment by pressing the button at front bottom of bag compartment then just pull the two apart (a gentle lever may help). Then turn the base over and undo ONLY the four deeply recessed screws (you will need a cross-head screwdriver). Turn the base right-way up again and lift off the cover. You will then see the belts.
If you find the belts are both good, or if you find one broken and need further help, post a reply here, tell me what you've found, and I'll guide you through the next steps.
Feb 16, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
How do I change the belt on my vacuum
Turn the carpet head upside down and look for visible screws at the front edge of the bottom plate. Inspect for others further back .Once removed the plate should hinge forward and separate from the base.
Clean burned rubber from motor shaft and spin brush roll when replacing belt to check for wobble or hair and fibre wound in to ends of brush.
Sep 05, 2009 | Vacuums
Changing belt
You will have to replace it, and it comes on the pump not separate.
Apr 07, 2008 | Bissell 1699 ProHeat Clear View Upright...
Changing belt
Turn vacuum over, remove looks like 3 or 4 screws, then the top cover will come off, exposing the belt and brush roll. Part 61520 style J belt.
Nov 08, 2007 | Eureka 2271 Bagged Upright Vacuum
Frigidaire Kenmore Washer Tub to Pump Hose 134455900 Logo
Top Kenmore Vehicle Parts & Accessories Experts
Tom Chichester
Jim Rus
Jim Rus
Matt
Are you a Kenmore Vehicle Part and Accessory Expert? Answer questions, earn points and help others
