Question about Electronics - Others
Volume label the disk in drive I cannot be formmett
    Sergeant:
  • 376 Answers
Does it have write protection enabled? Is yes, you will need to disable write protection in order to do anything to it. What are you using to attempt format, eg: software name and version number?
Posted on Jun 22, 2014
I am converting Fat to NTFS convert l:/fs:ntfs the drive is 2gb what do i enter for the volume label for that drive
You need to locate the current volume label on the drive.
The easiest way to do this is from the command prompt, you type in vol(space) then the drive letter you are converting & press enter. It will then tell you the volume name, and then on the second line the serial number for the drive.
Oct 07, 2014 | Microsoft Windows 7 Ultimate for PC
Volume label
to change the volume label right click my computer and go to manage. in the left hand column click on disk management in the middle pane you should see you HDD and Disk drive and other things if attached,
right click the drive you wish to change the letter of and click on change drive letter
Jan 11, 2014 | Transcend StoreJet Computers & Internet
Memory card 1GB volume label
My Computer. Right click Format > Volume Label.
My Computer. Right click Properties > Volume Label.
Start > Run / Search. Type cmd ENTER. Type label x: [name] x being the drive letter.
Nov 05, 2012 | SanDisk 1GB microSD Memory Card
I am using a 848P-A motherboard. I have just installed a SATA hard disk and changed OnChip IDE Device>Onchip Serial ATA to "Enhanced"(intend to use the new SATA drive as a secondary drive) but...
1. Does your new SATA hard drive can be seen in BIOS or POST. if yes 2. Does this new drive shown in "my computer" it should be no or under device manager is should be yes. 3. Use disk management.
To start Disk Management:
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
To create a new partition or logical drive on a basic disk:
  1. In the Disk Management window, complete one of the following procedures, and then continue to step 2:
    • To create a new partition, right-click unallocated space on the basic disk where you want to create the partition, and then click New Partition.
    • To create a new logical drive in an extended partition, right-click free space on an extended partition where you want to create the logical drive, and then click New Logical Drive.
  2. In the New Partition Wizard, click Next.
  3. Click the type of partition that you want to create (either Primary partition, Extended partition, or Logical drive), and then click Next.
  4. Specify the size of the partition in the Partition size in MB box, and then click Next.
  5. Decide whether to manually assign a drive letter, let the system automatically enumerate the drive, or do not assign a drive letter to the new partition or logical drive, and then click Next.
  6. Specify the formatting options you want to use by using one of the following procedures:
    • If you do not want to format the partition, click Do not format this partition, and then click Next.
    • If you want to format the partition, click Format this partition with the following settings, and then complete the following procedure in the Format dialog box:
      1. Type a name for the volume in the Volume label box. This is an optional step.
      2. Click the file system that you want to use in the File system box.
        You can change the disk allocation unit size, and then specify whether to perform a quick format, or enable file and folder compression on NTFS volumes.
      Click Next.
  7. Confirm that the options that selected are correct, and then click Finish.
The new partition or logical drive is created and appears in the appropriate basic disk in the Disk Management window. If you chose to format the volume in step 6, the format process now starts.
To format a partition, logical drive or basic volume:
  1. In the Disk Management window, right-click the partition or logical drive that you want to format (or reformat), and then click Format.
  2. In the Format dialog box, type a name for the volume in the Volume label box. This is an optional step.
  3. Click the file system that you want to use in the File system box. If you want, you can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
  4. Click OK.
  5. Click OK when you are prompted to format the volume. The format process starts.
For further Instructions click the link DISK.
Thanks, looking forward to fix your problem, just give a feedback if this helps.
Jul 01, 2011 | EliteGroup 848P-A Motherboard
When i am connectind my portable hard drive with my laptop is showing only taksbar not showing in laptop harddisk pls send messeage
Try connecting it to another computer and if it also slows down, something is probably wrong with your external hard drive and you should get a new one.
Mar 01, 2011 | Maxell 665203 USB 2.0 Hard Drive
How to format a new seagate external hard drive
Hi josernld
Formatting your drive for Windows Vista
STEP 1: Open Computer Management like this:
  1. Right-click on the Computer icon.
  2. Click Manage.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
STEP 2: In the pane on the left, under Storage, click Disk Management.
STEP 3: Right-click the drive that you want to format-be sure it's the correct drive-then click Format
STEP 4: To format with the default settings, in the Format dialog box, click OK, and then click OK again.
Formatting your drive for Windows XP STEP 1: Open Disk Management like this:
  1. Right-click on the My Computer icon.
  2. Click Manage.
  3. In the pane on the left, under Storage, click Disk Management.
STEP 2: Right-click on the drive you want to format. Be sure it's the correct drive.
STEP 3: If you want, you can type a name for the drive in the Volume Label box. This is an optional step.
STEP 4: Click the file system that you want to use in the File System box. You can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
Note: Before changing the default allocation unit size please refer to Microsoft Knowledge Base Article 314878.
STEP 5: Click OK. When you're prompted to format the drive, click OK again.
Formatting your drive for a Mac STEP 1: Open Disk Utility like this:
  1. Click Finder.
  2. Click Applications.
  3. Click Utilities.
  4. Click Disk Utility.
STEP 2: Select the drive you want to format. Be sure it's the correct drive.
STEP 3: Go to the Partition tab.
STEP 4: Click on the Current Volume Scheme drop-down menu and select One (1) partition.
STEP 5: Click Options. From the Partition Schemes provided:
  • Click on the GUID Partition Table radio button.
    --OR--
  • Click on the Apple Partition Map radio button.
STEP 6: Click OK. Select other options as desired (e.g., Volume Name, Format, etc).
STEP 7: Click Apply. The Partition Disk screen opens.
STEP 8: Click Partition. At this point, the volume dismounts from the desktop and the drive is partitioned and formatted.
Note: When Volumes are created, Time Machine may open, asking if you would like to use the volume for backups. Click Cancel to proceed.
STEP 9: When finished, select the Disk Utility from the Apple Menu and choose Quit Disk Utility.
Feb 17, 2011 | Seagate Computers & Internet
What is a volume label on Hitachi XL2000
it is the letter or name assigned to the partition of your harddrive
Oct 14, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
How to format my c drive help by dos
If you are running DOS(Command prompt) in Windows, your windows Operating System is installed in C drive and is Up and running then it is impossible to format the C drive because the whole thing is running in C drive and windows won't allow you to do so.
But if you are using a separate DOS O.S. and want to format C drive and If you want to format any other drive than c drive when your system is up and running then you can use the FORMAT command followed by the drive letter that you want to format.
here is an Examle to write in DOS..
Format C: /q
you can replace the C letter by any drive that you want to format. The /q Option is use to perform Quick Format. Here is a list of mostly used Option
Formats a disk for use with Windows.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/C] [/X]
"volume" Specifies the drive letter "/FS:filesystem" Specifies the type of the file system (FAT, FAT32, exFAT, NTFS, or UDF). "/V:label" Specifies the volume label. "/Q" Performs a quick format. "/C" volume will be compresse by default. "/X" Forces the volume to dismount first.
Hope this will help for sure.....cheers:)
Sep 28, 2010 | Computers & Internet
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
I cannot access my transcend pen drive
try changing the volume label at disk management on device manager
Aug 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
41 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
