Question about Toshiba E-STUDIO 450 Copier
Power on and machine wait warming up but print switch no work
Xerox work center5225 error code 116-331
Switch the power off, remove the HD, switch the power on, wait until machine warming up.
Switch the power off, reinstall the HD, and switch the power on.
Sep 28, 2016 | Xerox Office Equipment & Supplies
Http www youtube com watch
Power on the machine, open the front hatch as if changing a cartridge. Remove all the cartridges, then lift the locking arm holding the print head in place. Remove the print head and wash under running warm water. Dry it with a soft paper towel and replace it and the cartridges in the printer. Close the hatch and wait for the machine to reset. Hold the resume button until the power light flashes twice - it will do a self clean and test print.
Aug 26, 2014 | Canon BubbleJet i560 InkJet Printer
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Mar 07, 2011 | Xerox WorkCentre M-24 Color Copier
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Xerox Phaser 8550 error code 07,01043:90804
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Jan 19, 2011 | Xerox Office Equipment & Supplies
Xerox phaser 8560 DX error 07 010 43:14011
Hope this helps.
Dec 07, 2010 | Xerox Phaser 8560DN Laser Printer
My printer is displaying B200 error message
HI, I saw this possible solution for the issue hope this helps you.
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
Cheers!!
Sep 01, 2010 | Canon MX300 Office All-In-One Printer
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
Is there a 'reset' to factory default or a clear all settings/memory functions for this typewriter? Not sure what has been set, saved or activated. Would like to 'start over' if that is an option. Thank...
Switch the machine OFF.
While holding down the Margin-Release key, switch the power back ON....... The machine will begin to print a "self-test".
It will keep on printing the self-test until you switch the power back OFF. After only 1 line of self-test you can switch the machine OFF.
Wait 5 secs, switch the machine back on, and you will have cleared memory.
Sep 09, 2009 | Nakajima AE-740 Typewriter
69 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
