Boiler won't start
Called engineer who said it was a tank problem, he fitted a temporary pipe which is coming out of the top of the tank now not at the bottom. The pipe has a little round device before it goes through the wall to the boiler,this has a button on it. There is no oil coming through near the boiler when I tried to bleed it, I have also undone the small nut on the left hand side of the boiler to let any air out (engineers instructions over phone). There is oil coming out of the pipe OK before the small device mentioned earlier, but not a lot when it is put back on, is this right or is this the problem why the boiler won't start. Engineer can't get to us for a few days and l am reluctant to get him back it's costing me too much money, this is the third time he's been! Hoping someone can help me. many thanks.
  • 148 Answers
This sound like you have water flow problem that restricted the pressure to that switch
Posted on Feb 28, 2014
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: flame sputters
Hey welcome to the world of oil burner service!! :-) Theyare a finnicky beast to say the least. The problem you are having sounds like an air mixture problem. A combustion analyser would be the best tool to have but being that you probably don't have that try this. On the left side of the burner as you are looking at it is an air adjust ment ring and a fine tuning ring. the fine tuning ring is probably all you need to adjust. There is a screw that is usually right behind or near the pipe coming out of the pump and going into the burner. Loosen that and turn the ring away from you just a bit to close off some of the air and you will be fine. The burner is running a bit to lean. If you can see the flame turn the adjustment closed just until the flame color turns from a almost white color to a slightly orange color. Then you should be fine. Good luck!!
Posted on Nov 15, 2009
  • 3286 Answers
SOURCE: gas engineer wants to re-arrange coals correctly post service
yes he is right on that the postion off the coals have to be in the correct pstion to stop fire sooting and fumes coming from fire , if the coals are in postion you take them out and put them back the same as they came out , or there should be a picture of the coal lay out in the users book , or look on line for the make of fire , if the gas engneer cannot work this out then go to some one who can ,
this is basic gas fitting any gas fitter will know this if not walk away from them ,
hope this helps
Posted on Feb 07, 2009
  • 3286 Answers
SOURCE: my worcester 240 combi boiler. when heating goes
check the water pressure on the combi could be low or in the back of your manuel there is a fault finding guide which is very good and simple to follow .
Posted on Oct 02, 2010
What is going on with my furnace? When the burner comes on there is a knocking sound coming from the boiler area which continues as long as the burner is firing and continues for 30 seconds after.
knocking in systems is from fluid hammer in the pipes
It can be controlled in the first instance by the proper mounting of the pipes in the saddles ( more saddles the better --- less chance for the pipe to hit the wall or brackets )
The "hammer" occurs when a valve is opened and fluid stats to flow then the valve is shut off rapidly . the fluid is still flowing and so it hits that valve and the pressure builds up in the pipe ( knock) the valve is again opened reducing the pressure in the pipe only to shut off quickly again making the pressure again build up ( knock)
The are devices called accumulators available fro good plumber suppliers shops , that have a gas filled bladder in the unit
When the valve shuts off quickly , the flow of the fluid is absorbed against the gas filled bladder and then released when then valve is again turned on
this smooths out the stop/start action of the fluid and so stops the hammer or knock
The noise should be treated seriously as it will loosen of fittings and joints causing leaks and if extreme , will split pipes
As an example of what I am talking about take your garden hose and fit a stop hand piece to the end of the hose . turn the tap on , you will see the hose move as the water pressure builds up in the hose
press the trigger and see the hose relax
stop the flow quickly and again see the hose react
That relaxing and reaction of the hose is water hammer or knocking but you won't hear it in a hose , but with rigid pipes the action comes out as a vibration , like a drum being hit
Dec 30, 2015 | Heating & Cooling
Cold water pipe juddering non specific to any appliance and very random
Has the pipe got any clips on it in that area if it hash,that may be the cause ,Or maybe the pipe is running down.
Feb 19, 2014 | Plumbing
Potterton oil boiler won't start
check filter is not restricting flow due to clogging an check oil nozzel this might be worn. also check majic eye is not clogged wipe clean when did you last service
Feb 12, 2014 | Cars & Trucks
Leaking fuel pump
If the fuel is leaking into the car you will need the replace the seal on the top on the pump assembly not the seals on the pump itself but before changing the seal just double check the fuel lines are tight and the leak is actually from the fuel splashing out of the tank. The seal your after is referred to as the pump assembly oring ( big rubber oring around the top of the assembly a smear of silcone can be used as a temporary fix but erge you to get it fix properly as soon as possible and fuel fumes in the cabin can be extremely deadly)
Hope this helps
Jan 15, 2014 | 2003 Nissan Altima
Water pressure low on BAXi Combi 80e boiler
open bottom tap first then open top tap when water is to the leval you want turn off top tap then bottom tap.
Feb 03, 2013 | Heating & Cooling
Won't start
remove the fuel inlet pipe suction till fuel comes. than crank the engine .once the fuel comes out ,connect the pipe. next remove the out-let pipe and crank the engine till fuel comes out.and also check the fitting at suction for any leakage,breakages etc...
Feb 29, 2012 | 1995 Ford Explorer
Engine runs about 15 minutes then dies. acts like it is out of gas. will restart after sitting several hours.
Well iv had this problem a few times in the past so will let you try some of them ,
1/ Fuel pump in fuel tank overheating ORfuel filter not letting fuel passing ,ANSWER remove fuel pipe to engine and feed into a bottle turn on key and see how much fuel comes out without stopping, if ok go to fuel tank and check the breather pipe (make sure its clear).
2/ If engine runs well when you first start without missing and idles well,but then dies at 15minutes
when you try to start again dose it seem to turn over faster or slower?
3/When engine running check the rear tail pipe on exhaust check for smoke and put you hand over the pipe hard to stop fumes (dose engine run rough and stop?),as the muffler or converter can be blocked more so when hot.{use a glove on your hand}.
4/When the engine stops take out No1 plug lead and fit a spare plug in it and lay on top of engine and spin engine over ,does it spark?? as it could be the coil overheating which would also do it if no spark.
5/ Chech coolant sensorplug for bad fitting Also check Crank Sencer and coil wire to distributor.
Let me know the results Ron
Nov 19, 2010 | 2003 Kia Sedona
Noisy pipes with hot water baseboard heat
The natural expansion and contraction of the pipes due to the hot and cold water is what makes the pipes sing. I'm not aware of a fix without repiping.
Mar 21, 2009 | Plumbing
Domestic oil fired central heating. Keeps tripping out with no oil feed(has tiger loop and this is empty) If oil is drawn through filling tiger loop again boiler will fire up and run for betweeen 2 days...
many times the feeder tube from the bottom of the tank becomes perforated. the return tube is ok most of the time . try switching the 3 8 tubes from inlet to outlet and see if problem resolved. if so the the tube down into the tank is flawed.
Oct 31, 2008 | Heating & Cooling
How do you change the fuel filter in my 94 prelude SRV?
There 2 filters on your car:
1. By either the left or right suspension strut tower (gold colored canister)
2. By the gas tank
I suggest you replace both.
The one by the gas tank is like a prefilter and I will start with that one first:
Jack up car and put on axle stands or ramps then locate filter on the fuel line. Disconnect hose clamp from gas tank hose side FIRST (inlet) and use a spare bolt to block off the line otherwise fuel will spill all over the place.
Disconnect other side (outlet) then replace in opposite order.
You will need to use the grip part (not the cutting part) of a pair of pliers to GENTLY twist the hoses to break the seal on the rubber hose has made on the pipes as after years of clamping pressure they are bound to be tightly sealed on there. Remember to do it gently as you run the risk of crimping the pipes (not good!)
Also the filter should come with an arrow stamped on the body of it. Be sure to install the new filter with the arrow pointing towards the front of the car (this is very important as they are designed to flow only one way)
Sometimes these filters dont attach with hose clamps. In this case you will need a flare nut spanner (see below for explanation)
Now for the one in the engine bay:
It might pay to disconnect the battery to avoid the risk of fire.
I'll warn you that the fittings on this one are pretty tight so you will probably need a big bar with a socket to crack them.
The top fitting is what is known as a banjo fitting whereby a big bolt goes through a ring that is connected to the pipe.
Below this ring will be a hex (like a nut as part of the body of the filter). Attach an appropriately sized spanner on the hex then attach the bar with socket to the nut.
The spanner on the hex part is used to stop the filter from twisting while you apply pressure to the bolt to undo it (you may need someone to help hold the spanner). Only undo it untill the boolt has 'cracked' then leave it.
The other fitting (inlet) will either be on the bottom of the filter or at the top by the outlet but either way directions are the same:
You will need whats called a flare nut spanner (also called a pipe spanner) the right size for the nut fitting. It's like a ring spanner but with a cutout in it to slip over the pipe and over the nut fitting.
You also have a hex type fitting on this side too so attach appropriate sized spanner, attach the flare nut spanner and loosen as you did the other fitting (using the spanner to stop the filter twisting).
Take both pipes off but be careful with the banjo fitting side as there are copper sealing washers and you want to remember where they go (replacement washers should come with the new filter)
Replace washers and fit pipes in reverse order, attach battery, start up and enjoy :)
Hope this helps :)
Aug 03, 2008 | Honda Prelude Cars & Trucks
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
