Question about Belkin (F5D7132) 802.11b/g Wireless Access Point
Laptop not connecting to network
I am having a problem with my router. My laptop can see and connect to my router and says it is connected to my network, but I can not access the internet nor any other computer on my network.
Haved u tries Unplagging your Cable or DSL modem and also unplug the router.  Connect them again and this shoud fix your problem.  If not unplug both again but this time also Reset the router after its on.  hope this helps
Posted on Oct 30, 2007
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect to my laptop. internet i working on my desktop computer. i have belkin wireless G router. i have unplugged the router but still unable to connect.
Once its connected you will have the blue light in the belkin router
1.Turn on the wireless switch in your laptop
2.Click on start menu--->control panel--->Network and internet--->Network and sharing
3. In the right hand side click on "Change adapter settings or Manage network connections"
4.You will see the wireless network connection
5.Right click on wireless network connection and click on Connect/Disconnect will be able to see the network name,try to connect it. will be connecting and then connected
8.try to able to go online in the laptop
Jan 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
X360 and PC connect - Laptop doesnt!
Looks like you may have WEP security on router and WAP on laptop - or vice versa. Change the laptop to match the router.
Oct 23, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
I can only connect to router with ethernet cable and not wirelessly on one laptop and a PC but can with another laptop
If i have understood u correctly u have 2 laptops n 1 desktop.1 laptop going online.desktop and other laptop not connecting.As u r able to connect laptop wirelessly to ur router,u have configured ur router ie created a wireless n/w with network name and password(if its secured connection).You are not able to connect may be bcos u have not scan for the network in your desktop and other laptop so scan and connect to the network .If u want me to guide through scanning steps im ready to help u.
Sep 24, 2009 | NetGear DG834G Router
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Cannot connect to wireless network
To connect to the linksy's router you will need to run the linksy's setup disc on each pc in that netwrok.
Mar 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7132) 802.11b/g Wireless Access Point Logo
81 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
