Question about Casio PATHFINDER ATOMIC SOLAR WATCH PAW1100-1V
10BAR reset time
I need a english manual for my watch which is a Cybeat WR 10BAR
perhaps if you search Google you will find what you look for .
Oct 16, 2015 | Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
The hands on my Citizen watch (movement caliber number C320) don't reset properly. I have followed the factory instruction several times with the same result: the minute hand moves to a position 5 - 10...
This is normal. The watch begins timing when you reset it. That 5 to 10 minutes is the time that it took you to do the all reset procedure and you can see that the same time is shown in the digital display - so everything is aligned. It is actually pretty cool that it does that. Source: just did the all reset having dropped my watch. Love this watch!
Apr 13, 2011 | Citizen Watches
I have a Ricoh watch that has " ATRANTA Water Resistant 10BAR" on the face. Face is red in colour, has day and date scroll. Day of week can be seen in English or (guessing)Chinese or Japenese script. Back...
Ricoh Elemx AT Corp. is subsidiary company of Ricoh Elemex Corp.
The Hamilton Ricoh Watch Company, Ltd. was a joint venture (60% owned by Hamilton) and only existed between 1962 and 1964. Electric parts were made in Lancaster, PA while the mechanicals parts were made in Japan, the watches also being assembled in Japan. The movements are marked "Ricoh 555E", but are the same as the Standard Time Corp. 130E (fitted in Hamilton's Vantage range), which in turn is very similar to the Hamilton 505.
Although the factory was turning out 1000 / month, very few were sold. Marketing was handled by Ricoh but they failed to break the stranglehold and monopoly that Seiko had in the Japanese stores; in the end, most were sold on US military bases in Japan.
The partnership was dissolved in 1965; some of the Hamilton Ricoh movements were re-cased as Vantage and sold in the US.
Now Ricoh is owned by Elemex and they still producing watches. Follow this link and see for yourself:
http://www.ricohelemex.co.jp/en/products/req/
Unfortunately, I cant give you any details about your watch, except that the 10BAR means your watch can withstand 10BAR pressure, and that is 10 meters under water.
The bar (symbol bar) is a unit of pressure equal to 100 kilopascals, and roughly equal to the atmospheric pressure on Earth at sea level.
Rate me, please.
Feb 28, 2010 | Watches
How to change to time setting of CITIZEN WATCH CO.
Purchased a Citizen watch and it did not come with an instruction manual. How can I get one?
Sep 07, 2009 | Citizen Watches
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
My timex watch is not right because the time is 24 hour time and i want to know how to change it to normal time
Select Time reset button (right lower side) until seconds flash
Select Start button on face and cycle through until 24-HR
Select Lap/Reset
Apr 13, 2009 | Watches
Watch stopped running
Examine the caseback of the watch. You will find the lip (small gap between the case and caseback). This is exact point where to insert watch openers blade and pry caseback up.
Rate me, please.
Mar 26, 2009 | Watches
How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Sep 29, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Need an instruction manual for my Casio Triple Sensor watch
Hi there!
This site is quite useful - http://www.theusermanualsite.com/
Just log in with your Email & postcode to get a PDF of the information it holds.
If this assists you, Please rate as Fixya! (It's free)
Jun 21, 2008 | Watches
Casio PATHFINDER ATOMIC SOLAR WATCH PAW1100-1V Logo
14 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
