Question about Canon Sure Shot A1 35mm Point and Shoot Camera
Camera doesn't work
I've bought a "Canon Sure Shot A1 Panorama Date" and inserted a new CR 123A Battery. But nothing happens, the cam doesn't work at all. In the back of the cam there is a CR 2025 battery but I think this is only for the date function. Is the cam probably broken or do you think that it maybe work if I change the CR 2025 battery?
jackboy
  • 2985 Answers
SOURCE: Canon A450 internal battery problem?
There are cameras with 'fixed' internal batteries to maintain date/time they are long lived and not usually replaceable.
If this is such a model and it is new then a replacement should be forth coming from the vendor or Canon.
The vendor is the first stop then Canon support
Posted on Jan 25, 2008
SOURCE: Date/Time Set Won't Work
Write to Canon's customer service. I dropped my camera in water briefly and wrote them. They offered me the chance to replace my camera at an outstanding price or have it repaired. Give them a try!
Posted on Sep 15, 2008
  • 58 Answers
SOURCE: in my canon Power shot sx100is . how can i get the date on image
Good evening!
Bad news. For the date embedded feature, the image size is FIXED to the 2M (1600x1200) setting with the compression set to Fine.
The only other way I can think of, is if you are printing from software that came with your camera. When you start the software and transfer your photos, there will be a box to check if you want to add a date stamp to your photos.
Sorry about that! Mine does the same thing, only I never put the stamp on mine.
Hope this will be ok!
Posted on Oct 25, 2009
  • 7 Answers
SOURCE: I have a canon A720 IS with the same problem
arignote,
i have the canon a720IS and was having similar problem with my date/time. once i discovered the small cr1220 battery next to the regular battery compartment, i replaced it but the problem still was there.
i looked closely at the cr1220 compartment and took a toothpick and just pulled the metal prongs out a bit, so that they were in better contact with the cr1220 battery. ever since then i've had no problems.
good luck.
chris c
Posted on Oct 29, 2009
  • 1335 Answers
SOURCE: how to adjust date stamp for canon power shot
You can download the user manual for the camera at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=324&modelid=17480
To set the date stamp:
1. press the power button
2. select a shooting mode.
a. set the dial mode to Auto
3. select 2M
a. press the Func/Set button
b. use the up and down arrow to select "L"
c. use the right and left arrow to select the "check"
4. press the DISP button to switch to [Date & Time] with the left and right button.
The instruction are on page 21 of the user guide.
Posted on Dec 08, 2009
Canon AF35mm 2 (Quartz Date) Film Camera, How to set Date?
Go into the camera menu, it should have a section called Initial setup or something like that.
Jun 27, 2017 | Canon Sure Shot 80 Tele/Date 35mm Point...
I need an instruction manual for a Canon sure shot a1 panorama date camera
Ordinarily the panorama feature is utilized like this: you choose a panorama subject, and move your camera on a straight horizontal line with keeping your shutter down, and trying to capture the whole scenes into the lens. You can also stitch several common photos into one panorama picture(in vertical, horizontal, tile, 360 degree, 3d) with some programs like ArcSoft Panorama Maker.
Oct 09, 2011 | Canon Sure Shot A1 Panorama Date 35mm...
I have a canon power shot A70 digital camera and I cannot get it to turn on even when inserting new batteries.
I don t have a solution, but I got a similar problem. When I install new batteries, they only last for maybe 10 snaps- snaps ,then the "battery" light comes on and camera shuts off. I ve tried several sets of different batteries so its not a battery problem.
Power shot A70-15 8.0 pixels 6X zoom
Maybe someone can help us out
Jerry
Mar 29, 2011 | Canon PowerShot A70 Digital Camera
I got the Canon Power Shot G9 camera for almost 3years . It has been running well. But last month, somehow I could not operate it. It is not battery issue. At first I thought the battery was so old, so I...
The Canon G9 has a design defect, two screws fall out inside the camera and short out the fuse. If you've never had it fixed for no power before this is most likely what has happened to your camera.
Do a Google search for "canon g9 no power repair" and you will see a full repair service including return shipping of your camera for just $85.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Mar 07, 2011 | Canon PowerShot G9 Digital Camera
I have an old 35mm Canon Sure Shot 70 Zoom. There is film in the camera, but the battery is dead. I can't find the owner's manual and want to know if I'll expose the film if I open the camera to change the...
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
Sep 04, 2009 | Canon Sure Shot 70 Zoom Date 35mm Point...
Can't find battery compartment for canon sure shot tele
The battery cover should be on the left side of the body looking at the front of the camera next to the strap holder.
Mar 26, 2009 | Canon Sure Shot 80 Tele/Date 35mm Point...
Its a canon XH-A1
Please go to Display setup > TV Screen display > OFF
very simple procedure.
Dec 20, 2008 | Canon XH A1 Mini DV Digital Camcorder
Canon 40D can not turn on
Same problem. Fully charged main battery. In my case, I hadn't used the camera in over 6 months. All I did was pull the main battery and then pulled the small CR 2016 button cell battery located inside the main battery compartment and re-inserted both batteries. The camera made a quiet click and then turned on with the main power switch and asked to reset the date and time. Works fine now. If this doesn't work just purchase a new button cell.
Sep 17, 2008 | Canon EOS 40D Digital Camera
Canon Sure Shot A1 35mm Point and Shoot Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
