Question about Panasonic TX37LZD80 37 in. LCD TV TV/HD Combo
No picture only sound
Sound ok changes channels but no picture
Sound OK picture washed out. can see image change channel slow 5-10 seconds to change image. picture is viewed better at an angle. unplugged next day OK now back to washed out unplug does not help
You have problem that something is heating up causing you to loose picture then once you shut it off it cools down and works need to have it serviced
Dec 16, 2015 | RCA 26LA30RQD 26 LCD TVDVD Combo
Problem with audio and vidio
Is this a problem only with the cable box or also with oother sources as well?
Feb 03, 2008 | Pioneer PDP-6100HD 61 in. Plasma...
TV no sound but pictures ok, changed channels ok
The mts/sap function on your television might be enabled. Locate the audio settings on your television and make sure you are set for either stereo or mono. You may have an audio or mts button on your remote. If not this should be in the menu.
The cable company may have made a recent change and the tv may need to be channel buffered or you may need to complete another channel scan.
Aug 18, 2010 | LG 37LH55 37 in. LCD TV
Philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Mar 26, 2010 | Televison & Video
Thmy samsung LN-T3242H - 2 years old - the picture
Hi:
Make sure under your audio options you are in stereo mode and not it SAP, (Special Aided Programing).
Dec 24, 2009 | Samsung LNT2642H 26 in. LCD Television
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
DS204D-S26 No Picture Soundis OK
check the power supply proper voltage supply
Sep 21, 2008 | Sova Digital DS205-S32 Television
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Grundig Xentia - sound but no picture
in your tv is malfunctioning high voltage, the audio is generated without the help of high voltage sistem how happens commonly in many other tv
Aug 07, 2007 | Grundig GF70-600 TV
Panasonic TX37LZD80 37 in. LCD TV TV/HD Combo Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
