Question about Konica Minolta Office Equipment & Supplies
Konica Minolta c 0204 c300 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Open the Second draw and remove the paper from behind the draw. THEN REMOVE THE PAPER ON THE LEFT SIDE OF THE DRAW NOT A STORAGE AREA ITS FOR 11 x 17 PAPER!!!!!
If those two fail, you have a burned out 2nd draw lift motor or worse case the control board that controls that motor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 22, 2016
kfrejlich
SOURCE: Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It happens when You put to much paper od while moving (for example). Solution: take out the paper tray 1 and 2, remove the paper from the space behind the trays.
Pixel
www.mojito-networks.com
Posted on Jun 23, 2009
e-Guru
  • 3917 Answers
SOURCE: Hi, I am using Konica Minolta
Hi
To set duplex printing, follow the below instructions:
1. Select 'Properties' from the Print dialog.
Note: Properties may be indicated as Advanced, depending on the application software.
2. Click the Page Setup tab.
3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
4. Select 'Duplex Printing'.
When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed.
5. Specify Staple Side. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. If necessary, click Specify Margin... and set the Margin width.
6. When the setting is completed, click the OK button at the bottom of the window.
If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
If Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages.
7. You will be prompted, while printing, to remove the printed page and reload it in the ASF.
8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Please accept the solution if it's helpful. Do get back to us for any further query.
Posted on Sep 16, 2010
xeerie
  • 347 Answers
SOURCE: Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Posted on Oct 20, 2010
  • 118 Answers
SOURCE: konica minolta bizhub c300 how to reset fuser unit
you need to get a small pico fuse(small green resistor like part on wire harness in fuser. or if your fast you can remove the fuse and short the wires turn on the machine then count to 10 and unshort them. fuser will reset. this is the only way or get a new fuser (too spendy) write me back if you need help.
Posted on Nov 29, 2011
  • 3 Answers
SOURCE: how to install Konica Minolta Bizhub C300 through
you can try add a printer in printer & faxes mode to install kmc300
Posted on Jan 18, 2012
Can anyone send me a firmware for Konica Minolta Bizhub C300
Its size is larger than 20MB but i will try to send you the link.
Mar 06, 2015 | Konica Minolta Bizhub C300 All-In-One...
Another one is konica Minolta c300 given me a code of 3101
TO clear the code did you open and close the front door. Powering the machine on and off does not reset code open closing the front door does. If that does nor work recommend getting a new fuser/fixing unit.
Feb 26, 2015 | Konica Minolta Bizhub C300 All-In-One...
My machine problam code c-0204
what model machine?????????????????
Jun 12, 2014 | Konica Minolta bizhub Office Equipment &...
P7 p28 p5 c300
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Mar 21, 2014 | Konica Minolta Bizhub C300 All-In-One...
C450 c-0204
Pull out the cassette and check the paper capacity not to exceed the maximium level. Clear any irregular or untidy paper if any.
Feb 24, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta c300 error c2555
replace the yellow image unit
Nov 25, 2013 | Konica Minolta Bizhub C300 All-In-One...
Printer status report printing on each print in konica minolta bizhub c300
Printer status report, you can turn this off simply go to Printer properties check there.Check in printing preferences option.Also check in your Microsoft Office setting.Printer report printing is turned on simply turn it off.
Jan 10, 2012 | Konica Minolta Bizhub C300 All-In-One...
Oct 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
