Behringer GMX1200H Just got my Behringer GMX1200H amp back from a friend of a friend after he borrowed it for about 4 orso months, after a few days of getting it back I got the cab out of the garage and plugged it in and now I can't get a clean sound from it, it always has a bit of distortion which is very noticeable with powercords. I also can't/find it EXTREMELY difficult to get a good sound from the amp anymore and when running a distortion pedal through it. I know he was using it through a pc/laptop to record some music and unsure if any settings could of been changed through that?? Also sounds like a really quiet effect is running, but that could just be me hearing things. The amp still pumps out alot of volume but it just doesn't have the distortion like it use to before I lent it out. What could of been the cause of this?
  • 14 Answers
SOURCE: P200 Subwoofer all quiet
Try taking tha cable out of the amplifier and touching it, this should create a low hum, as your body is sending throug a small current. if this works then you may have accidently switched the sub woffer on in the amplefier. if however you get nothing through the sub then you may have a dry joint in the solder, or the board may be dead. Other option, try an other cable. they also use lead based solder so they do get old.
Posted on Dec 13, 2007
micromaster
  • 3614 Answers
SOURCE: Samson G-Track recording volume issue
Is this the first time you experience this problem.?
Posted on Jun 04, 2008
SOURCE: Sound card for acer aspire 5600
dsf
Posted on Nov 14, 2008
  • 238 Answers
SOURCE: Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Posted on Jan 24, 2009
SOURCE: Left Speaker Stopped Working
I think I had a similar problem. My speakers were brand new and after a while I lost my front left and rear left speaker. I'm not sure about you guys but after fiddling around with the settings it worked after I changed the "S/PDIFoutput sample rate" from 48 to 96 khz. I have no clue what I did, but it worked for me. I am running logitech something or rather speakers with VIA HD audio deck drivers
Posted on Jan 29, 2009
Behringer gmx1200h plays for awhile then cuts out
Sounds like main amplifier section circuit fault. Check all the supply connections and make sure that there is no loose contact, before you do anything. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 05, 2016 | Behringer Audio Players & Recorders
Tip
TIPS TO EARN MONEY
Before jumping into these money-making tips, here are a couple things to keep in mind. First, these tips are aimed at helping you make money fast. They are NOT going to make you rich. One or two tips should earn you an extra $50-100 over the next week. Implement all the tips, and you could see a couple hundred dollars added to your bottom line. But do not expect quick riches.
Second, you need some planning and a few days to work with. That planning should include ways to start saving money.
If you are in a situation where you need quick cash today, then you're in a crisis -- and you probably need to borrow money from friends, relatives, a bank, or (last resort) a fast cash outlet. This article is aimed at those who have at least a few days (preferably a week) to work with.
At the time of this article being published, the economy is in turmoil. A deep recession is certain. Worse is possible. It's time to stop borrowing money. No more debt.
Your priority is to create a positive cash flow each and every month. That means you must spend less money than you take in. Your income must exceed your expenses. So, until you can increase your income, you must decrease your expenses to put yourself in the black each month.
Some ways to save money include:
  • Eat more at home.
  • Pack your lunch for work.
  • Cut back on your driving, and that probably means cutting back on your extracurricular activities.
  • Consider downgrading or even eliminating your cable or satellite TV
  • Coupons, coupons, coupons
Cut back on your monthly expenses. You'll see how this alone can put more money in your pocket.
on Jun 02, 2010 | Computers & Internet
What Is The Difference Between A Direct Loan And A Loan Guarantee?
A direct loan is an arrangement wherein a lender gives cash or assets without delay to a borrower and the borrower is of the same opinion to return the property or pay off the cash, usually along with interest, at a few future factor(s) in time. usually there may be a predetermined time for repaying a mortgage, and usually the lender has to bear the risk that the borrower might not repay a business loan (even though present day capital markets have developed many ways of managing this risk). A business loan guarantee is a loan subsidized by way of a government organization which undertakes to repay a loan in case the borrower defaults. Normally, business startup loans are guaranteed loans.
Feb 02, 2016 | The Computers & Internet
Behringer ms 40
I'm not sure what kind of problem you are having on this but I have been trying fix a Eurolive B215D powered monitor for a friend for over 6 months. I have found that I could fix it in a few hours but, can't find any record of the components used. Standard resistors, caps, and others but certain things like output transistors and more specialized spec components can't crossover to generics for repairs. The only way to get them is through Behringer manufacturer AND they want to sell you a new on instead of fixing the old one. Can't seem to get parts for Behringer equipment. I have talked to other techs that say the same.
Mar 12, 2013 | Behringer Ms40 40w Active Powered Studio...
Faint & distorted audio on am sw & air
When I bought mine, I too thought it had no audio, until I opened the user's manual and read about the initial setup. After performing the steps described in the manual the sound came as if by magic.
Nov 03, 2012 | Eton Satellit 750 AMFMSW Radio
Behringer Xenyx 1622FX - How do i get a passive stage monitor to work?
You need to send your signal from the mixer to an amplifier and then go from the amp to your speakers.
Alternatively, buy a pair of active speakers.
Jun 06, 2012 | Behringer XENYX 1622FX Premium 16 Ch Mixer...
The fuse holder and fuse fell out while in upright position. I borrowed the amp from a friend. Where can I find the cap that holds the fuse in, and what fuse do I replace it with?villaslasolas
You are in big trouble! You will wait months to get the part from Behringer. Here is link to similar itrem from Digikey.com. Search for keyword "fused entry"
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=708-1332-ND
This may or may not be the exact match and they have several similar types. You will have to buy the whole power entry unit as finding the exact "fuse drawer" is not likely.
I believe you shoukd use a 6.3 amp fuse in the unit and the size to fit the fuse drawer in the entry unit,
Feb 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Down on one channel
Check your pan pots are centered.
Jun 08, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Monitor blowen, mixer-monitor channel went out
THE MONITOR OUTPUT AMP MAY HAVE BLOWN...COULD MAY ONLY BE THAT THE JACK IS BAD OR JUST A COLD SOLDER JOINT.....OR IT COULD BE JUST ABOUT ANYTHING IN THE MONITOR CHANNEL PUSH BUTTON MASTER VOL FOR THAT CHANNEL TAKE IT APART TAKE A LOOK AROUND BEFORE YOU BRING IT TO A REPAIR SHOP IT CANT HURT GOOD LUCK
Jan 07, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
37 people viewed this question
 Grubhead
Grubhead
