Question about Welch Allyn Propaq Encore 202 EL Monitor
Unit does not turn on when connected to expansion module
How do I pinout a cable for Avaya Expansion Module
You can use a regular 4pin cable to connect the module to the phone.
Oct 07, 2014 | Avaya Lands Phones
What causes an acer aspire e14 gives memory error messages on start up
Try this solution... Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. Align the keyed (notched) edge of the memory module with the keyed area in the expansion slot. Insert the memory module into the slot at a 45-degree angle until it is seated.
  7. Push the front edge of the memory module down until the retention clips snap into place.
  8. After reseating the memory module, replace the memory expansion cover and then replace the screw.
Step 3 - Replace the battery
  1. Insert the battery into the notebook.
  2. Push the battery into the base enclosure until you hear a click.
  3. Connect the AC adapter and turn on the notebook.
Sep 05, 2014 | Computers & Internet
Avaya expansion phone 16 module flashing green light.
Reboot the control unit. If you dont get a solid light on the phone 16, power everything off, then power up the phone 30 wait 15 seconds, then any other expansion module, 15 seconds after the last expansion module, power up teh control unit...
Dec 05, 2012 | Avaya Computers & Internet
Suddenly a very thin vertical yellow/white line appearing on my HP desktop monitor? pls help
Does it appear THE MOMENT you turn the unit on?
If it does, then you will have to run the monitor's self-test function by turning it on with the data cable (the one that does NOT connect to the power outlet) DISCONNECTED from the computer.
If the line still appears, then the monitor is faulty & cannot be "repaired". Usually, the entire LCD module is replaced.
If the line does not appear in the self-test mode, then check if it's connected to an ON-BOARD display adapter (typically found in the back of the machine, towards the middle area, towards where the ethernet cable and USB devices plug in) or a EXPANSION CARD (normally located towards the BOTTOM part in the back of the machine).
If it plugs in to the on-board slot, then the motherboard may be faulty. If it plugs in to an expansion card, then it's the card that may need to be replaced.
Of course, these are merely possibilities, but the most likely failing component here is the monitor itself. Busted display adapters very rarely, if at all, manifest these horizontal or vertical lines and STILL boot up. Regardless if it's on-board or expansion card, a failing display adapter would normally have either no display at all, or it would just simply stop booting up (screen remains dark: no lines).
Aug 12, 2011 | Computers & Internet
I have added cisco 7916 expansion module to 7965 cisco phone.Now when i started the phone,phone works but expansion module screen shows cisco logo and lights continuously flash.
I know it may be late (definitely late), but have you defined in the CallManager, that your phone has a "side card"? If CallManager does not know that it has to push an additional firmware to a particular phone, it will not work.
Good luck,
Mike ' CCNP, CCVP, CCSP, CCDP, MCSE, etc.
Headset Adapter Co.
Headset Adapters for office phone system
Mar 21, 2011 | Cisco Systems - Unified IP Phone...
Two extension phones won't ring but all other functions work fine for our AVAYA system. These extensions are plugged in to our expansion module I suspect the module is defective and need instructions on...
Power the carrier off. Pollow the power cord on the right side of the 5 slot carried. There will be a pull switch or a rocker switch. turn off.
Once power out, remove bad module, there is a tab on the top OR bottom depending on the age of your carrier. Pull card away from wall, and insert new card.
Power system back up.
Oct 08, 2010 | Avaya Partner ACS 308EC (108463001)...
I have the panasonic cq-c8303u radio and i would like to hook up the ipod to it. any tips?
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Mar 23, 2009 | Panasonic CQ-C8303U CD Player
Nortel 1140E IP Phone, Expansion Module 1100 series not working
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Dec 09, 2008 | Nortel 1140E
Welch Allyn Propaq Encore 202 EL Monitor Logo
492 people viewed this question
Top Welch Allyn Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Welch Allyn Boating Expert? Answer questions, earn points and help others
