Question about Crock Pots & Slow Cookers
Bush AE66DCA set on automatic how do I put it back to manual operation
My oven has accidentally been switched to automatic and I dont know how to reset to manual operation
How do you work the pc crock pot
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. Quoted from manuals on line
http://www.manualsonline.com/support/other/slow-cooker/manual-2538852
Sep 07, 2017 | Crock Pots & Slow Cookers
I need a instruction manual for a rival automatic
The manual is available from http://kitchen.manualsonline.com/manuals/mfg/rival_1/4450.html
Jul 20, 2010 | Rival Automatic Steamer/Rice Cooker 4450...
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
This is ridiculous. I just want the manual for the corningware sc 60 slow cooker so I can print it out. Why all the runaround. This should be simple
1. Turn off and unplug the slow cooker first.
2. Plug it in, but (yes, I know this sounds crazy) DO NOT turn it on.
3. Set your cook time and it will automatically set the temperature based on the cook time.
he The magic number is 7. Anything set for less than 7 hours will be cooked on high. Selecting a time more than 7 hours will result in cooking on low. Once the cook time has expired the cooker will automatically switch itself to warm until you turn it off. Follow these steps and you should be able to enjoy your cooker again! I don't know who was in charge of this type of setup for programming but they should be demoted at least - no wonder there are so many questions online about this one. Sure hope this helps you!
D
D
Nov 29, 2008 | CorningWare SC60 Slow Cooker
Rival SCV655 Slow cooker
There are three settings.
The third - as found on a new products description:
Product Description:
6.5 litre capacity,ideal for to up to 6 people,Removable and dishwasher safe stoneware for easy cleaning,Mlicrowave and oven safe stoneware pot,Dishwasher safe glass lid,2 cook settings,Keep warm function,Recipes included,Brushed chrome finish
- Its a keep warm setting.
Kind regards,
Nicholas
Sep 27, 2008 | Crock Pots & Slow Cookers
Corningware slow cooker 6qt
If you choose the auto selection the slow cooker will cook for three hours on high then will automatically reduce to the low setting.
Aug 22, 2008 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
