Question about Kitchen Ranges
Glow worm Ultracom 18hxi F1 fault - Kitchen Ranges
Hi just bought a VW Caddy Diesel 2006 and having problems starting it in the morning. Changed glowplugs but not made any difference. Any suggestions?
Hi there?
Have you checked if they have power goint to the glow plugs with the ignition on.
What is the temperature sensor reading in the morning, if it reads little bit worm then it thinks that the engine is worm and it wont power the glow plugs.
May 24, 2011 | Volkswagen Eurovan Cars & Trucks
Service manual for glow worm boiler micron soff
Can you give a model number and more info? I think you mean a micron 60ff in which case it is here: http://www.glow-worm.co.uk/stepone/data/downloads_sd/8d/00/00/micron-60ff.pdf
Jan 02, 2011 | Heating & Cooling
Hi the coyle is flashin and it says engine work shop on dash
The glow light flashing is an indication that there is fault. Often this is associated with a blown brake bulb or faulty brake switch which is an electronic switch at the base of the brake pedal itself. It often goes faulty on these Golfs causing the glow worm to flash. An odd way to indicate a brake fault I know but there you go - thats the way VW do it! Check the actual bulbs first though. Hope this helps.
Jun 20, 2009 | Volkswagen Golf Cars & Trucks
Combi boiler Glow worm 24ci digital fault
refere to glowworm expert advise
Apr 03, 2009 | Water Heaters
Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Apr 02, 2009 | Water Heaters
Glow worm combi boiler
check the pilot line for an obstruction. check the millivolt generator that's supposed to keep the pilot valve open. check for a high limit control being bad.
Dec 14, 2007 | Desa International GWP20T GLOWARM Wall...
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
