Question about Blu Hero Pro Mobile Phone
My Blu hero phone will not turn on. The battery is charged.
Happened all of a sudden.
Tip
Battery Tips for the Sprint HTC Hero.....
Battery life on cells phone, especially the hoard of smart phones coming out, can be very short, especially right out of the box. The following are some tips to extend the time between chargings for the Sprint HTC Hero (and probably the European Hero as well as the Verizon Eris).
• update your system software to version 1.56. To check which version you have, go to Settings > About phone > scroll to see software version. To update, go to Systems updates from the same menu, and select Firmware update.
• turn the brightness down of your screen. The brighter the screen, the more juice you use from the battery. Go to Settings > Sound and Display > Brightness.
• turn off bluetooth, wifi, GPS, and mobile web when not in use. I place these widgets on one of my screens to have easy on/off access. Go to (+) > HTC Widget > Settings. I turn off everything at night, turn on mobile web during the day, and turn on the others as I need them.
• turn off the "Always On Mobile Network" setting. Go to Settings > Wireless Controls > Mobile network settings > Enable always-on.
• limit the amount of push to sync email and other applications.
• turn of the automatic updates for apps like Weather, Facebook, Twitter, email. With the apps constantly checking and pulling data, the battery will drain much quicker.
I can usually go about two days between chargings with moderate use and three days with light use.
Good luck.
on Dec 09, 2009 | HTC Hero Smartphone
My go pro hero 3 wont switch on, wont charge and shows no red light. basically does nothing. was working 4 days ago but seemed to have short battery life. the camera is only 3 weeks old! Could it just be...
I have the exact same problem. I was able to charge the battery twice, but both times it ran empty after 20-30 min., and now the camera is dead as a brick. Absolutely nothing happens when I try to charge or turn it on. :(
Three weeks old Hero 3 Silver.
Jan 14, 2013 | GoPro Digital Hero 3 Digital Camera
My husband HTC hero turned itself off and won't come back on we have charged it and took the battery out still notthing. Please help
Try different chargers if you can, if that doesnt seem to work then you may need to test the battery. A common issue with a phone older than a year is that the charging port will go out through wear and tear. If this is what happened to your husband's hero you may need to take it to a service/repair center from your service provider. The fix is usually about 40$ and will in most cases take only a day.
Mar 06, 2011 | HTC Hero Smartphone
Why does my hero 200 phone suddenly turn off battery reads full
Sounds like you got a faulty battery, the only way to fix it is to buy a new battery i'm afraid.
Mar 06, 2011 | Samsung Cell Phones
My phone suddenly turn off and can't turn on.it happened when i was charging my phone.i try to connect it with my pc but nothing happen...help me please
THE PROBLEM COULD BE FROM EITHER ANY OF THESE TWO
  1. BATTERY; open up the back cover of the phone, bring out the battery, use your tongue to taste the negative and the positive part terminal of the battery to see if it tastes charged, if it tastes charged.then drop the battery.
  2. POWER I.C; Since the problem commenced during charging, the current might have affected the POWER I.C.you need to replace the power i.c of the phone from the panel.
So, I'll advice you to meet an experienced technician around you for the replacement of the POWER I.C
Jan 11, 2011 | Cell Phones
The speaker stopped working on my htc Hero all of the sudden. I cannot hear ringers or media at all - it acts as if it's constantly in vibrate mode.
Your Speaker is burnt out just found that out with mine today. Took it to Sprint store Tech & they replaced it with a brand new speaker free of chg because I have insurance otherwise you'll be charged about $40
HTC Hero
SPRINT
May 20, 2010 | HTC Hero Smartphone
My phone wont take a charge on my car charger or my house charger, this happened suddenly, help
might be the battery or charging port....u can go to carrier store and test a battery there, if not battery its charging port...call them and ask for replacement
Mar 22, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Blu Hero Pro Mobile Phone Logo
18 people viewed this question
Top Blu Cell Phones Experts
Lawrence Oravetz
ace87
Level 1 Expert
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
