Question about Tablets & eReaders
WILL NOT SWITCH ON. BATTERY okay, CHARGES OKAY
COMPUTER WILL NOT SWITCH ON, THE BATTERY IS FULLY CHARGED AND EVEN WITH CHARGER PLGGED IN, COMPUTER WILL STILL NOT SWITCH ON. RED LIGHT COMES ON WHEN CHARGER IS PLUGGED IN BUT NOT WHEN UNPLUGGED
    Sergeant:
  • 274 Answers
If your computer recognizes it when its connected to the PC then you may have luck reinstalling the firmware.
If not, the unit maybe dead.
Posted on Feb 13, 2014
4 Suggested Answers
SOURCE: the AC adapter light does not come on when plugged in
This happened to me recently. I did as the engineer said and it worked.
Posted on Feb 03, 2008
  • 367 Answers
SOURCE: My m1300 works great as
Take the battery out of your device and inspect the pins on the tablet. If they are very dirty or if something is stuck between pins, it could cause the battery to fail at transferring the correct power for the device in order for it to stay on. If all the pins look ok and it still doesn't work after putting the battery back in, you may have an issue with the motherboard which will need to be serviced by the manufacture.
Here are some battery LED codes from the manual:
LED steady green --> battery 100% charged AC plugged in LED steady amber --> battery charging AC plugged in LED steady red --> battery overheated or defective (replace it) LED flashing green and amber --> battery discharging abnormally (replace it) LED slow-flashing amber --> 10% battery charge remaining AC unplugged LED fast-flashing amber for only a few seconds --> 3% battery charge remaining AC unplugged
Chris
Posted on Aug 15, 2011
  • 4 Answers
SOURCE: battery charges but even if its 100% and i remove the charger it will tll battery low
Problem is is the battery already. Try to borrow or sample another battery of the kind then figure out if you need to buy one or if it's still in waranty.
Posted on Sep 30, 2012
My zeepad isn't tuning on what do I need to do.I charge it for a of hours and still not coming on.
make sure the battery is ok and fully charged. try to switch on with the charger charging. Is the charger ok ?. if it switches on with the charger hooked up the battery is at fault.
Dec 25, 2014 | Tablets & eReaders
What's wrong with my device? It powered off even with batterly life left and won't turn back on even when plugged into the charger.
can you pull the battery out for awhile (30 mins to an hour) the put the battery back in and charge the device without turning it on until it is fully charged.
Oct 01, 2014 | Tablets & eReaders
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
It says it is charged but when i take the charger off it doesn't work
Sounds like the battery is dead. Thats what normally happens when products have bad batterys. If you can tell me the name and model number of your teblet i would be happy to look into for you.
Feb 01, 2014 | PANDIGITAL Tablets & eReaders
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Why is there a red cross on the battery icon of galaxy tab though its fully charged?
I studied my galaxy note 10.1. when i use the original wall charger it charges well, fast an no red cross appears. when i hook it to the usb of my laptop then the red cross apears and the tab reports that it is not on battery ( look at the time on battery it does not change) the battery also remains at the same charge level that it was when i hooked it up. when i use the car charger it does the same as with the laptop. my conclusion is that when hooked to the car and/or laptop the battery does not charge, but the tablet is running of the power from the external source and not the battery. this seems to be a very clever move from samsung to preserve the battery when it cannot be charged by the device it is hooked up to.
Nov 12, 2011 | Samsung Galaxy Tab (GTP1010CWAXAR)
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
