Question about Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television
Trutech tv When I plugged my TV into my computer to use as a monitor, the picture comes on and then fades out after 10 seconds.Gateway computer with XP Professional. HELP
  • Anonymous Feb 15, 2009
    brought a trutech tv got home up the cable cord to it and it shows nothing how do you which from tv to cable tv
  • 367 Answers
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your no picture problem, unless there is something else wrong.Hope this helps.Thank You very much!
Posted on Apr 08, 2008
    Problem Solver:
  • 8 Answers
Turn off OGI and select Manual picture settings.  Same thing was happening on my Apple Mac.
Posted on Nov 18, 2007
It`s more likey to be the setting on the display seting menu ati grathics cards are best for two screens
Posted on Oct 27, 2007
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
I have a spacesaving kitchen 10
I have the same problem as the above question. The picture goes off and there is only sound
Feb 17, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
My tv screen starts normal then fades gradually The tv is working, but all I get is a black image
Check the CRT ground wiring. I saw this on a computer monitor after I forgot to reconnect the wire from the ground line around the picture tube. It would start normally and fade out over a period of five-fifteen seconds.
Caution: pull the plug and wait several minutes, then check for voltage between the bare wires around the outside of the picture tube and chassis ground before you put you touch anything. If you get voltage, this is definitely the problem, and I've just saved you from a nasty shock (could be almost as high as 2nd anode voltage). If you don't get voltage, inspect at will.
Jul 11, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Can't get sound when used as computer monitor
comp sound Tv
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on TV (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on tv. If no picture on tv make sure you computer graphic card is set for dual display .
Feb 02, 2009 | TruTech PM1919BXA1 19 in. LCD TV
TruTech PLV1615T has Sound but No Picture
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Aug 06, 2008 | TruTech PLV1615T 15 in. LCD Television
TV picture fades, then shuts off
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Jun 10, 2008 | Samsung TXF2899 28" TV
Customer service number for Trutech
I too purchased TV on Black Friday from target in 2006 and w/in the last month the picture went..The sound works, but no picture..cust service tel #:888-252-6252..I tried to call but was on hold so long...I'm actually on hold again...If you happen to figure out what the problem is, please e-mail with resolution..TV isn't even a year old..Can't find the warrenty...
Nov 08, 2007 | TruTech PLV16190 Television
Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD Television Logo
283 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
