Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
My sony PD177 firewire por is Not working, it can't connecting to my PC
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
The problem with pd 177 its that it can burn the fire wire port and its not able to communicate with the pc you should check that the fire wire ports to see if they are working if they are then its the fire wire port that needs to be replaced.
Check the ebay you might be able to find one there.
hope that helps as my selfe had the same problem .
Posted on Feb 13, 2014
2 Suggested Answers
ripleymojica
  • 643 Answers
SOURCE: How to fix Sony DCR TR7000 Firewire port
if you can open camera make sure the ribbon cable from port is seated all the way. if not replace input board.
Posted on Jun 02, 2009
How to connect PD 177P sony to computer through i.connect cable?
My sony PD177 firewire por is Not working, it can't connecting to my PC.
Jun 22, 2011 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Hi there cannot connect i link to my pc no connection on my pc any advice would help
Usually what you would do is buy a IEEE-1394 interface card and install it in your PC in an available slot on the motherboard. You can buy these for less than $20 and with a little tech knowledge about PCs many people can install the card themselves. The IEEE-1394 is called i.Link by Sony. If you are running Windows XP, or Vista, the drivers are already installed. Reboot PC and the new card should be recognized. Use the 4-pin to 4-pin firewire cable to connect camcorder to PC. You will need software to capture your video which should have been supplied by Sony with your camera. For Windows 7, you need to install LIVE Photo Gallery. Your camcorder was setup to work with Windows XP so an alternative may be to just find a friend with an older PC with a firewire card already installed running Windows XP. I just did this very same thing on my PC and it worked. Got the firewire card from Amazon.com for $3.95 VIA brand from Taiwan. I used Windows Movie Maker to capture video. Sony also sells a stand-alone DVD recorder which connects to a camcorder and requires no computer to create DVDs of your video.
Mar 18, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
We have Handycam HDR-HC3. Our old PC worked well importing videos, but eventually died, and we upgraded, but didn't check new pc didn't have Firewire. We have a spare Vista PC which has Firewire socket,...
http://forum.videohelp.com/threads/260169-Sony-HDR-HC3-driver-issue
I searched under HDR-HC3 firewire driver and got the above link.
It says the following:
Hi..
The problem was a missing MSDV.SYS file.
Thanks
D.
Actually, on the Sony site it says that no additional drivers are required to connect the camera in Windows XP, Vista, or 7.
But, the user of this camera and firewire noted that he was having trouble convincing windows of this.
Another link that talks about the firewire problem follows:
http://www.avforums.com/forums/camcorders-video-editing/480748-cant-copy-video-pc-sony-hdr-hc3.html
You can find more links by searching under 'HDR-HC3 firewire driver' or related searches to find the solution to your problem.
I hope this helps.
Jan 16, 2011 | Sony Handycam HDR-HC3 HDV Digital...
My pc cant see the cam , i have win7 &xp , need my pc to read it as divce .
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 13, 2011 | Sony DCR-TRV285E Digital-8 Digital...
I have a noise problem with sony pd 177
i want to bye camera but i could not decide which one is better pd177 or pd170
Sep 04, 2010 | Sony Video Cameras
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Jun 02, 2009 | Sony Handycam DCR-TR7000 Digital Camcorder
I can't get Firewire to work on my Sony DCR-PC101e.
No special soffware or driver is needed provided that your PC has a firewire port ...
Dec 15, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Which cable do I need to conect my camcorder to pc
if you need a visual on it, there is a video on www.HandBookLive.com under Electronics. The example is Belkin IEEE 1394 cable (Firewire and I-Link compatable) and it connects digital camera to a laptop.
May 28, 2008 | Sony Handycam CCD-TRV78E Camcorder
Sony DCR PC105E I-link failure; any advice? (Please!)
Ideas.. 1. Is the camera set the same as before during capture? 2. Does the camera work on another PC or Mac? 3. Look up WinDV on google.com and see if that works. (It's free.)
Sep 14, 2005 | Sony Handycam DCR-PC105E Mini DV Digital...
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
50 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
