Question about Ben Sherman R294.00BS Mens All Black Watch
Keeping time I have a Ben Sherman R294 which was bought just before Christmas 2013 as a present. It seems to keep losing time, and can be several days out (and hours) if left for a while. Is this a problem with the watch, or battery, or a common issue that can be solved?
2 Suggested Answers
SOURCE: I bought Ben Sherman R424 watch from Amazon
Solution 1 seems a little off for mine it's the bottom right button you hold in which brings up the date and then the country its set to starts flashing. Then the bottom left hand button to move to the time. Use the top right button to scroll and left bottom to move to the next input. When your done push the bottom right once.
Hope this helps.
Posted on Mar 31, 2011
I need a replacement brown leather strap for Ben Sherman watch R472
Hi call watchsupermarket .co.uk 0845 600 1511 for availability ...cheers
Jul 15, 2017 | Ben Sherman Watches
Set time on Ben Sherman R424
Press and hold the top right button till it beeps. Then press the bottom left button to scroll throught the hh:mm:ss, use the top buttons to increase or decrease the number. Finish by pressing the bottom left button until you cycle through back to the time display.
Mar 27, 2011 | Watches
CANNOT REMOVE LINK FROM BEN SHERMAN WATCH
If it's similar to my Ben Sherman watch it will have what looks like a screw on one side. It is in fact not a screw but the 2 sides of the split pin - which you simply push out using a map pin, small strong screwdriver, or similar. If you look inside the links you should find arrows to indicate which direction to push the pins out - usually pushing the end opposite the "screw" end. Note: It takes a fair strength to get the split pins moving.
Jan 15, 2011 | Watches
Wanna set time on my ben sherman R424
Aug 16, 2010 | Ben Sherman Strap Watch
I cant find my manual for my ben sherman r424 watch. it only has four buttons. why cant i figure this out?
You will not find BEN SHERMAN watch manuals online. Visit www.bensherman.com and click on CONTACT US or SUPPORT tab. There you'll be given contact phone number.
Mar 30, 2010 | Watches
I bought Ben Sherman R424 watch from Amazon Marketplace. It has arrived with no manual, and I cannot figure it out. Any help please??
Hope this helps.
Feb 25, 2010 | Ben Sherman Strap Watch
My Stauer Atomic won't stay connected to time signal
These watches only need to see a signal several times a day, not necessarily continuously.
If it keeps good time, don't worry about it.
Jan 05, 2010 | Watches
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
Apr 08, 2007 | Luminox Navy Seal Dive 3001 Wrist Watch
Ben Sherman R294.00BS Mens All Black Watch Logo
12 people viewed this question
Top Ben Sherman Watches Experts
Tom Chichester
Jeff Tilburn
Jeff Tilburn
masud
masud
Are you a Ben Sherman Watch Expert? Answer questions, earn points and help others
