Question about Watches
My watch always need to change its battery Recently i have change a new battery and it wont last even for a week Can you advise if the problem lies in the battery or watch since i have change few brands of battery already Mine is suunto core black alu version
Benimur
  • 6966 Answers
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
SOURCE: Swatch Skin #SFK254 ,Time always late
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
Posted on Dec 19, 2009
  • 2501 Answers
SOURCE: My wrist watch is continuously losing time. It is
go to the Timex web site "timex.com".
Scroll down to the bottom of the page and select "manuals/downloads."
Select "Product manuals downloads"
Enter you model number in the search box.
Choose your download from the list.
Posted on Jan 05, 2010
  • 66 Answers
SOURCE: Changing metric to Imperial on Suunto Vector
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
It's in the manual. I did it on mine.
Posted on Aug 03, 2010
My son gave me a Anne Kline watch a year ago but it has stopped running. I changed the battery twice but it still runs some and than stop. What do I need to do?
Watch might need a superior or best quality battery that hasn't been in stock for long...
Few modern watches need a new battery every year and most in my experience will last at least a couple of years so the watch is probably faulty and it is a shame you didn't return it while it was under warranty.
A decent jeweller/horologist should be able to check this and advise you.
Jan 23, 2017 | The Watches
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 | Watches
I have an oakley minute machine. Last week i went to a shop to replace my batter, after about 15 mins. i went back to the shop to pick it up. The repairman told me that the hour hand wasn't working and...
You should not even be thinking of fixing the watch yourself!
The problem, and the responsibility for remedying it lie solely with the repair man. If your watch was not broken, and only in need of a new battery when you took it in, then the fault is entirely caused by them.
Take it back to them and demand that they re-instate it to good working order.
Oct 07, 2017 | Watches
I recently took my fathers ingersoll duo watch to a repair shop to have new batteries installed unfortunately they were unable to separate it and get inside. could you please tell me how to do this.
I wouldn't advise you to do it yourself, as without special tools and knowledge you will just damage that watch. The best way is to type in your browser: watch repairs + your area. You should find plenty of them there. Contact by phone first and explain what sort of watch you do have and what's needed to do. Ask watch repairer on the phone, because only him/her will be able to understand specific needs. Do not explain to manager or just personell - they are useless. When you are satisfied with the answer over the phone, go there and give your watch for whatever it needs.
Jun 02, 2011 | Watches
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
Feb 03, 2009 | Bulova Watch
Rado watch stopped working
It sound like a fault. Be careful who looks at it though and what they charge - a complete new quartz movement for most watches, even fancy ones like your don't cost as much as £90 so almost all of what you are charged is labour.
Feb 02, 2009 | Rado Diastar Anatom Jubile watch
My bulova watch isn't working
Even you change a new battery with desame size and volts not working.The problem is in the terminal where going to put the battery.The terminal had a dirt or a film residue that comes out from the battery,you better clean terminal by scratching the old film,the lying down terminal is negative,,the side terminal is positive you better observed polarity if happen inter change the battery side it will not works.If not working, even you clean already terminal,short the terminal connection for 3 seconds,If you have a flourescent with a ballast,put your watch lying where there is strong vibration for five minutes, your watch works 100% txt me whatever the result so i know it's ok.
Jun 02, 2008 | Bulova Men's Watch
Watches Logo
95 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
