Question about Prestige Appliances PRT295FFCS (9.3 cu. ft.) Bottom Freezer Refrigerator
My prestige fridge freezer temperature isn't working. fridge is 20c and freezer is 5c
My fridge temperature is 20+ degrees and my freezer is 5 degrees. all my food has defrosted please help
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
IPhone 5 temperature limit?
The iPhone is a very durable piece of equipment; it is built to have an operating ambient temperature of 32 to 95 degrees F (0 to 35 degrees C) however it is not built to withstand temperatures of -4 to 113 degrees F (-20 to 45 degrees C)- which means you should probably think about getting a different phone.
Sep 16, 2012 | Apple iPhone 5
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
I have an amana refrigerator w side by side with freezer at the bottom.what is the best temperatur settinfg is most economical for this type refrigerator?
if you have a fridge/freezer thermometer great.leave inside each one for at least 12 hours to get average temperatures if in use. Answer .. the optimum temp for the freezer is -18/20c.0f, for the freezer and +2/5c.34/36f for the fridge.
Mar 10, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My fridge is a hotpoint a fridge freezer after sitting in the garage for a while the freezer is working but the fridge is not what do i need to do
fist check the temperature of fridge,should be +2-+5c.
freezer should be between -18 to -20c.it is possible that you f/f was designed to operate between +10 to +35 degrees.most are, so as you say its in your garage/shed the ambient temp is too low for it to operate efficiently,hence fridge feels warm(compared to when it was indoors.mine is in shed with a greenhouse heater.kept at +9.....
Feb 24, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Jan 02, 2008 | Refrigerators
Prestige Appliances PRT295FFCS (9.3 cu. ft.) Bottom Freezer Refrigerator Logo
29 people viewed this question
Top Prestige Appliances Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Prestige Appliances Refrigerator Expert? Answer questions, earn points and help others
